Reply 2360 of 29776, by HighTreason
- Oldbie
I smoke around computers and nothing bad happens. It just makes the dust harder to clean out. Long term... Screw it, I won't be around to see it because the cigarettes will kill me long before anything happens. I have actually used cigarette smoke to test cooling systems for hot-spots.
wrote:Is that an outside wall? If so, why are all those wires exposed?!
Yeah, but they're satellite cables so they don't carry much power. The main focus is that the lead has come away from the wall. It is actually a larger problem than apparent in that photo;
The porch is supported by PVC pipe, though they were originally on steel and I do not know why they replaced it. I didn't think PVC drain pipe was used as a structural material but I guess the city council did not get the memo on that. As you can see, the pipe is bent and the porch visibly leans to one side. The whole thing is actually moving away from the house and is now over an inch away from the wall - meaning all the weight is on those PVC tubes and it is right over the front door.
Interestingly, between yesterday and today, the house used almost £3 of electricity with nothing switched on or even plugged in (The house is completely empty). So that was weird. More immediately noticeable was that somebody had been in and unlocked the doors. As this was early afternoon, I assumed the council had been in to do something before I got there, would have explained the floorboard being put back and tidying the lengths of tack strips I had ripped up. I returned tonight to remove the tack strip (If I get out of the contract, the council will bill me for leaving trash there, even though it is their trash) and somebody had tidied it again - I had moved it earlier - moved the loft hatch, replaced the board again and propped a door open with a brick... Nobody has broken in, so it must be somebody who has a key outside of council hours. This implies I have a plain old intruder, possibly hiding out in the loft. Luckily I never left tools or anything in the house. Me and my friend also saw someone looking in through the window but did not mention it until we had left, implying somebody was actually there. I did not give chase because it was dark and I have no idea who they are or what they are trying to do.
