Reply 240 of 260, by Matchstick
mbalmer wrote on 2026-02-15, 03:38:The issue is that the typically-available (and inexpensive) I2C screens are either the size you see, or literally just too large to fit properly in a 5.25" drive bay unless you have a way to secure the OLED glass to the front panel without breaking the glass or the flex PCB tail -- and even then, it's a REAL tight fit. There are sizes in the middle that can be bought easily, but they tend to be extremely expensive when compared to the typical sizes and also don't necessarily work out-of-the-box with the I/O libraries that the existing hardware interface code is compiled against.
Not to bring up the competitor, but what display is the PicoIDE using? Is it not I2C?
I think I kinda answered my own question though... it uses a ESP32-C3 to handle the front panel separately from it's main RP board.
