Another PS/2 Mouse ISA (ISA8) card adapter
Reply 240 of 278, by maxtherabbit
rasz_pl wrote on 2023-09-26, 15:16:
I forgor about that one, even posted in the thread
Reply 241 of 278, by aries-mu
Wow!
But, it looks very convoluted to me. Isn't there any simple ready to use box or something?
They said therefore to him: Who are you?
Jesus said to them: The beginning, who also speak unto you
Reply 242 of 278, by rasz_pl
click to receive bacon https://www.serdashop.com/PS2TOSERIAL requires usb power supply with micro usb, like old phone charger
Reply 243 of 278, by aries-mu
rasz_pl wrote on 2023-09-26, 16:12:
Thanks so much!
about power supply: which I can draw with a simple Molex-to-USB (female A-type) power adapter cable, to which then plug a male USB A to male Micro USB cable, am I correct?
Reply 244 of 278, by rasz_pl
You can wire 5V power straight from molex to J1 connector pins 2-VCC and 6-GND instead of USB cable with two converters 😀
Reply 245 of 278, by aries-mu
rasz_pl wrote on 2023-09-26, 17:25:
Oh 🤣
Well, I never did such a thing...
Reply 246 of 278, by feipoa
While I haven't tested all of these serial port to PS/2, or USB adaptors, I've tested about 6 of them and everyone one of them had trouble with mouse pointer, or tracking lag thru my KVM, getting worse at higher resolutions. Rio444's PS/2-serial emulator card was the first which had no noticeable lag. If you aren't going thru a KVM, maybe these other adaptors will work well enough. But if you are, be advised that the first link Rasz posted, contains this message:
Support for use on KVMs has been added as of version 1.1.1. It works fine on my one, startech branded, KVM that I have test with. Given that TinyUSB is a bit picky, your results may vary.
Reply 247 of 278, by aries-mu
feipoa wrote on 2023-09-26, 21:22:
oh got it, thanks! I definitely plan to use KVMs
Reply 248 of 278, by feipoa
aries-mu wrote on 2023-09-26, 11:53:
Roman (the creator of this project) just specified what follows: […]
copper wrote on 2023-09-26, 11:28:
Yes, please send me the files by PM.
I can't estimate the cost until I put everything together but it doesn't seem like it will be crazy.
I'm in the US. The boards are small; they should ship cheaply enough.
"No need to forward this to everyone on the forum. Otherwise device will appear on eBay soon. There are people who get rich from other people's developments. I am passing on this documentation on the condition that you will make the device only for yourself and will not sell it on international trading platforms, like eBay.
I wrote about this earlier on the forum.
Please, confirm the reception of and agreement to the above.
Thank you!
This sounds to me like any form of batch assembly and distribution would be in contravention to the creator's wishes. Assemble a unit just for yourself.
Reply 249 of 278, by aries-mu
feipoa wrote on 2023-09-27, 07:15:
It might seem so, but he also refers to his comment in the forum where he specifies his wishes more clearly. The comment is on page 11 of this Thread, and states:
"Please note that I consent only to the non-commercial use of these materials. You can make devices for yourself, your friends, maybe sell some surplus on the local market, but nothing more."
Direct link here:
Re: Another PS/2 Mouse ISA (ISA8) card adapter
Indeed, when I emailed him what is going on and what Copper intends to do, he was okay with that.
But thanks for your concern though!
Reply 250 of 278, by feipoa
OK, excellent. I thought maybe he changed course on his wishes, making them stricter, based on the more recent comments you provided. However, if at present, he referred you to his earlier forum comments on page 11, then it does sound like some small batch production for friends is permitted. In which case, whomever decides to make a batch of these, I'll take 1 unit (pending cost analysis).
Reply 251 of 278, by dm-
93.77 KiB
Author selling his cards on RU e-platform. got one this summer, works nice in my 486 rig.
Reply 252 of 278, by Jester
It looks easy to print the boards using the gerber file. Ordering the parts in the BOM and assembling will take some soldering skill.
234.93 KiB
https://cart.jlcpcb.com/quote
128.64 KiB
Reply 253 of 278, by rasz_pl
you can skip ENIG, fingers should use hard gold which jlcpcb cant do, ENIG will just rub off after couple insertions so is useless and no better than normal HASL finish
Reply 255 of 278, by rasz_pl
jlcpcb cant do proper gold fingers, only typical Chinese fake 'good enough' but in reality not good enough ENIG. You are paying $15 for the color, not the actually usefull property of real gold fingers (being hard and corrosion proof)
Reply 257 of 278, by Many Bothans
Kudos to Rio444 on this brilliant project. Just unfortunate timing to source for the community.
Has anyone had any luck recreating the card with BOM/Gerber yet? (@Copper?)
RetroRig: AOpen AP43, AMD 5x86-133, 512k L2, 128MB FPM, Diamond Stealth III S540 32MB Savage4, Soundblaster AWE32 w/ 16MB
Reply 258 of 278, by aries-mu
sorry, I added a reply so made a new reply below
Reply 259 of 278, by aries-mu
copper wrote on 2023-09-26, 11:13:
aries-mu wrote on 2023-09-26, 10:59:
If somebody comes up, then I'll forward the files.
I'd love to try to build these things for the Vogons members. I need two of them myself.
Upping this. Any news?
Also, I was wondering, what if on such old PCs one actually connects the PS/2 mouse (instead of the keyboard) to the 5-DIN connector via a simple 5-DIN to PS/2 adapter, and then finds another way to connect the keyboard somehow? Perhaps via serial port... Would that be a problem? Would the keyboard get an input lag? Would the keyboard be lagged on a KVM serial switch?
