Reply 240 of 547, by rasteri
Eivind wrote on 2024-05-14, 19:39:I don't have the two UART0 pins connected to anything on the TL 2.1 (pins 7 and 4, right?). I could always solder on something if needed, but if it's relatively simple for you to make a fw version that spits out relevant info on the PS/2 keyb lines, that would be easier for me! 😜
OK latest commit has hub info in the debug output.
Note that if you haven't used the menu in a while the process has changed - you have to hold down the button for a few seconds to make the menu appear.
Also pressing the button without holding it will cycle through AT/XT/Amstrad modes so be careful!
