Reply 2420 of 5230, by appiah4
BetaC wrote:
appiah4 wrote:
Depends on whether your Yamaha card has a wavetable daughterboard. If not, the AWE is better for late DOS because it offers basic GM MIDI through its AWE extensions for many if not all games. On the otherhand, CQM is inferior to OPL3 so it's a tradeoff, but not one you will lament too much for late DOS.
I doesn't have a wavetable board, but I do have an SC-55 Mk1 sitting on my desk.
In that case the AWE64 would only bring a lower noise floor to the table. I wouldn't bother with it unless your Yamaha card is a low quality one.
Reply 2421 of 5230, by BetaC
It's an A151-A00. A picture of it is a page back in the Bought Hardware thread.
As for the memory I previously mentioned, they are all below:
The attachment IMG_20190819_210751.jpg is no longer available
The attachment IMG_20190819_210755.jpg is no longer available
The attachment IMG_20190819_210807.jpg is no longer available
The attachment IMG_20190819_210811.jpg is no longer available
The attachment IMG_20190819_211045.jpg is no longer available
Reply 2422 of 5230, by BetaC
Second part:
The attachment IMG_20190819_211125.jpg is no longer available
The attachment IMG_20190819_211121.jpg is no longer available
The attachment IMG_20190819_211105.jpg is no longer available
The attachment IMG_20190819_211058.jpg is no longer available
The attachment IMG_20190819_211052.jpg is no longer available
Reply 2423 of 5230, by BetaC
Part Three:
The attachment IMG_20190819_211152.jpg is no longer available
The attachment IMG_20190819_211149.jpg is no longer available
The attachment IMG_20190819_211142.jpg is no longer available
The attachment IMG_20190819_211138.jpg is no longer available
The attachment IMG_20190819_211131.jpg is no longer available
Reply 2424 of 5230, by chinny22
The AWE also gives you SB16 vs Yamaha SB Pro
You have the option to try out AWE option in games that support this, vs General Midi (but most will say its inferior)
Neither will have hanging not bug with the Roland
Yamaha has true OPL, AWE doesnt.
I'd say for late dos and that you have external midi the AWE is the better choice, but both cards are good
Reply 2425 of 5230, by BetaC
chinny22 wrote:
The AWE also gives you SB16 vs Yamaha SB Pro You have the option to try out AWE option in games that support this, vs General Mi […]
I guess I will swap them out depending on the game. Thanks.
Reply 2426 of 5230, by imi
I just spent half an hour literally dumpster diving... found 2 legs for an external SCSI CD-Rom enclosure and an SCSI terminator... it might have been me who accidentally put them there in the first place 🤣
Reply 2427 of 5230, by BetaC
The attachment IMG_20190822_004756.jpg is no longer available
I managed to salvage a SCSI and Parallel Zip reader from my work, and a basic ass MS mouse.
Reply 2428 of 5230, by x0zm_
Was on the way to the shops and came across a junk pile, with seven PCs! Sadly - all empty. I did find some goodies in the pile though. It was admittedly a bit tough carrying a box of sound cards and a bag full of miscellaneous bits around through the supermarket, but that's life when you walk to the shops and don't want to leave things there and hope they'll be there on the way back. Excuse the bad quality late night photos.
First case that excited me. Only has the PSU & FDD inside. Maybe the ODD too? No Motherboard though.
Another Celeron beige box with no motherboard.
A bag of 5.25" to 3.5" bay adapters and 5.25" covers.
A box of sound cards! Score!
Anyway, shopping happened and I squeezed it all into my backpack alongside the bay covers and adapters. Let's take a closer look at what I brought back.
Nothing special. Five 5.25" to 3.5" adapters which can be quite handy. A few 5.25" covers, a bunch of PCI brackets and two FDDs which were filled with dirt and leaves, so I'll likely junk them again. They're too new to be worth cleaning up, imo.
The PCI cards are boring, but free AWE64 and XWave w/ YMF724 cards? I can't argue with that!!
Overall, the box had the following for those interested:
  • 1 x CT4830 - Sound Blaster Live! Value
  • 1 x CT4780 - Sound Blaster Live! Value
  • 1 x CT4520 - Sound Blaster AWE64 Value
  • 1 x Labway XWave 5000
  • 9 x CT4810 - Sound Blaster PCI
  • 1 x CT4750 - Sound Blaster PCI 128
  • 1 x Unknown ESS chipset card.
Pretty cool!
Finally, the HP case. I liked it, so I brought it back. I haven't opened it yet since it's late, but if it will fit a regular mATX board I'll be keeping it around.
I have the feeling based on what was in the pile, it was from a scrapper. Could be wrong but I can't imagine much else.
Reply 2429 of 5230, by liqmat
Always next time...
The attachment stuff on my back.jpg is no longer available
Reply 2431 of 5230, by Warlord
That one is the best card out of your box. Assuming it works. Its a awe64 value. If you find a ram module it will be able to do sound fonts.
Reply 2432 of 5230, by luckybob
Keep that 64 value. Their prices are going to skyrocket once the re-release of the 64 gold gets done.
AWE64 Legacy
Reply 2433 of 5230, by jaZz_KCS
x0zm_ wrote:
Finally, the HP case. I liked it, so I brought it back. I haven't opened it yet since it's late, but if it will fit a regular mA […]
Not quite the same model, but very close. Close enough to senile inform you that you are (according to this seller) rich. RICH I TELL YOU!
unknown.png?width=925&height=468
[/SenileSalesmen]
Reply 2434 of 5230, by x0zm_
Great to hear I'm rolling in cash with that case. Or since it's empty, the more likely use is a fun HTPC. 🤣
Went back tonight. Walked again because exercise is fun. Some bloke took the opportunity to line up all the cases - presumably after looking through them all and being disappointed.
I picked out one more to bring home. I have an AOpen Slot 1 board, a lot of Slot 1 CPUs, a lot of memory, an 80mm radiator from the successful yet failed retro AIO experiment (yeah, I'm going there again), a newly found AWE64, a brand new PSU and no case to build in.
Tah-dah!
I also took the liberty of taking the case stickers off the other ones. There's a Designed for 98/2000 sticker as well but it isn't adhesive at all.
Inside is an AOpen (lucky, right?) 40x optical drive, a Panasonic FDD and a lot of 40 pin & 34 pin ribbon cables. There was a power supply which went right into the trash. Exterior needs some cleaning, interior needs some dusting but there's no rust. Thinking of going back for more, but I'd rather not keep too many empty cases on hand. That's just more to move around and store.
What a lucky year it's been for cool retro finds for me.
Reply 2435 of 5230, by Thermalwrong
That's a lot of CPU stickers, does it really have 3 CPUs?
Nice find, that's a great selection of cases 😀
Reply 2436 of 5230, by bjwil1991
Me guess is he has Slot 1 Pentium II, Celeron, and Pentium III as some boards do support PIII easily, either Slot 1 or Slotket 370 (Slot 1 to Socket 370).
Reply 2437 of 5230, by Merovign
(sees stack of old PCs on side of road)
(sighs and fills back of car)
I have a Dell Precision 450 that's been in the back of my car for like two months. But hey, dual Xeon and AGP - I'm sure I'll come up with *something*.
*Too* *many* *things*!
Reply 2439 of 5230, by x0zm_
I took every Slot 1 sticker off the cases there I could find and stuck it on there for ease of transport. I didn't know what CPU I'd end up putting in there so I'll just use the right one when the time comes. 🤣
Anyway, I played around and cleaned up the case today (a post for another thread) - but I will head back one last time tonight before it is collected to grab some parts from the other one of this case that was in worse condition. Looking inside, it was three standoffs + three plastic clips. I'd rather six standoffs, and the standoffs were an unusual size so I'll have to grab those.
I might also check out the other optical drives in those cases to see if there's any 24x or older drives since I'm short on those.
