Reply 25800 of 29867, by BitWrangler
- l33t++
Gatteric wrote on 2023-11-04, 15:42:BitWrangler wrote on 2023-11-04, 14:05:I know that's a modern desktop case, but that still looks like a lot more heat than I'd trust a desktop format to deal with. I'd be gutfeel limiting it at 65W CPU and up to 130W GPU
Hi BitWrangler
Yes I was a bit concerned about heat as well but after doing multiple benchmark runs and playing a few games, temps seem to be hovering around the 35c idle and 65c under load on both the CPU & GFX Card which is pretty good. It does have 2 x 120mm Noctua fans blowing over the CPU cooler as well which I think is helping
Ah good. I see you do have another vent or place to put a fan on the PSU side if things get hairy in hot weather.
