Far Cry
Reply 260 of 392, by PerryRhodan
Has anyone got a working link to the unofficial Far Cry 1.6 patch. It appears the main website no longer exists. http://www.farcrypatch16.de/
Thanks!
Reply 262 of 392, by PerryRhodan
I've already installed that patch plus the FCAM mod, but I still can't find any working links to patch 1.6. I guess 1.505 will have to do. Thanks anyway!
Reply 263 of 392, by lowenz
1.6 is kind of...strange patch.
Reply 264 of 392, by lowenz
Ah, another bug to fix (if possible via ASI script): bumpmapping issue caused by Z-fighting (bumpmap flickering on palms and maybe other trees):
Correct:
Moving the mouse around:
Reply 265 of 392, by VS11
Unfortunately, I don't have it installed anymore so I couldn't confirm it.
Is that just the regular x32 version without the exclusive content? Does it happen in the x64 version too with/without the exclusive content patch?
Is the motion blur off? Looks like it ...
Does it still happen in Windows Xp?
Can it be reproduced in WineD3D too?
Reply 266 of 392, by VS11
Also, did anyone manage to make the DOT3 bumpmapping, specular lighting work without texture bugs?
They are off by default, when turned on the sunlit textures on ground or in the distance lose completely their detail and indoors, the effects are not applied on floors, walls ...
Reply 267 of 392, by lowenz
VS11 wrote:
Unfortunately, I don't have it installed anymore so I couldn't confirm it. […]
Moving=Changing Aim from A to B, not moving around the camera
Reply 268 of 392, by VS11
Have you been able to test it in WineD3D and the other instances mentioned above?
Reply 269 of 392, by lowenz
Same problem in WineD3D!
It's like the bumpmap (is it a bumpmap, right?) pops-up and disappears changing the angle&distance of the camera.
Simple UV mapping problem?
Reply 270 of 392, by VS11
- Do you have the possibility to test it in Windows Xp too?
- How about the x64 version with & without the exclusive patch? If this happens in there too, it's a problem.
- By the way, what is the level of AA applied?
Reply 271 of 392, by lowenz
No AA.
Reply 272 of 392, by lowenz
It's a bug: Dege's d3d9 in lastest WIP of dgVoodoo 2 fixes the issue!
Re: WIP versions
Reply 273 of 392, by VS11
Use r_displayinfo = 1. The SM version used is displayed on the screen.
SM3 should be on by default if you have the Lighting set on very high in the ingame menu.
Also if you maxed out the ingame graphical settings through that menu you end up with r_Quality_BumpMapping = "3" too.
Reply 274 of 392, by lowenz
I know, with Dege's DLL I got SM1 ('cause it's the actual/intended scope of the release), without it (MS Windows D3D9) I got SM3.
Bumpmapping is automatically set to 2 with Dege/SM1 and to 3 with MS/SM3.
With SM3 + Bumpmapping=3 I get the issue.
SM3 is important for shadows, so I'll keep it and try to manually override the bumpmapping quality forcing "2".
Buuuuuuuuuuuuuuut, it's not the best solution at all (if working).
Reply 275 of 392, by VS11
There still remains the question if Windows Xp displays it correctly or if the x64 version with or without the exclusive content patch does it.
SM3 was introduced in the 1.2 patch, so chances are that if such a bug would have arose it could have been easily observed and addressed in the subsequent releases.
Reply 276 of 392, by VS11
Indeed SM3 introduces lots of improvements over SM2.
Reply 277 of 392, by lowenz
Bumpmapping Quality = 2 -> totally irrelevant to the problem
Reply 278 of 392, by VS11
I hopefully might be able to test it in the x64 version soon since some of the content was either changed or new one introduced as far as game assets go, levels were changed(new objects with bump mapping applied on, terrain texture shader and so on).
Unfortunately, I don't have a Xp machine to test that theory too.
Reply 279 of 392, by Res1s7
I assume everyone knows about the SilentPatch fix. I saw it mentioned in the thread but not specifically as a high performance fix for the land mass reflections. The way this guy sleuthed the solution is quite impressive. Far Cry 1 forever !
