Problematic Windows games list
Reply 260 of 296, by BEEN_Nath_58
Myloch wrote on 2024-10-03, 12:32:
The first three games of the Uncle Albert saga (original french title: Oncle Ernest) are well known PITAs in their restrict circle of aficionados. No way to use them on anything newer than XP, excluding VMs.
There's a slight hope to see them supported on ScummVM soon or later (later, probably).
The first game at least stops at a QuickTime issue. Any idea on how to bypass it, so that the focus can be on the real issue?
Reply 261 of 296, by Myloch
Exactly, since the QuickTime used (or macromedia director, I don't remember) is not compatible with post-XP OSes, there isn't really much you can do.
"Gamer & collector for passion, I firmly believe in the preservation and the diffusion of old/rare software, against all personal egoisms"
Reply 262 of 296, by BEEN_Nath_58
Myloch wrote on 2024-10-03, 17:25:
I was able to get past the QuickTime by allowing it to install as an administrator 🫡
I went one step ahead, put EmulateHeap and it runs to ask for an MPL file, then errors out. Unwarranted error
The game apparently runs with DxWnd but I haven't got there:
https://sourceforge.net/p/dxwnd/discussion/ge … 59ab7d5ad/#c95a
Reply 263 of 296, by BEEN_Nath_58
Not sure how but the Italian version of Windows 11, as described in my earlier post, plays the "mTropolis Windows Player" in the exact behaviour as my Windows XP does. Not sure what's so different, it is also reported that the Pentium Edition of MechWarrior 2 is heavily unstable in the Italian Windows while it does much better in the English Windows.
Reply 264 of 296, by BEEN_Nath_58
Sound related issue, disable sound devices. Issues in handling the MIDI device.
Reply 265 of 296, by BEEN_Nath_58
PBA Bowling 2 crashes randomly. Probably some memory error that was ignored in Win9x
I've Got Some Balls faces the similar fate, but on a bigger scale. At least the game has a remake:
https://github.com/thefinalcutbg/IveGotSomeBalls
Extreme Wintersports does something weird to explorer.exe that I have never seen in any other game.
Reply 266 of 296, by miller11568
Total Immersion Racing got a message saying, even if I've installed DirectPlay:
DirectX 8.1b must be installed to run the game
This can be run from the game set-up CD.
Are there ways to address this problem or can someone help me hex edit the executable?
Thanks in advance.
My operating system is Windows 10.
Reply 267 of 296, by BEEN_Nath_58
miller11568 wrote on 2024-10-09, 16:25:
Total Immersion Racing got a message saying, even if I've installed DirectPlay: […]
Thanks in advance.
Set Windows XP (service pack 2 or 3) compatibility on TiR.exe
Reply 268 of 296, by k24a1
I actually tried the 1998 PC release of glover again recently with a 9x system and nVidia 45.23 drivers. The game itself is framelocked to 20FPS but it runs perfectly fine. Settings don't matter, "3DFX Voodoo Chipset" will do, and it doesn't even use glide.
Reply 269 of 296, by Speedwarrior956
Warrior Reporting....
Another problematic game -a recent one that i'm currently "enjoyng"- is *Monster Jam* (Torus Games/Activision, 2007) which has NO SOUND during races. (The music for the menus runs fine, at the very least though.)
-Apparently there was a patch/fix for that issue floating thorough the web that seems to be MIA for being scanned and treated as malware. Or so i've read....-
Reply 270 of 296, by BEEN_Nath_58
Speedwarrior956 wrote on 2024-11-06, 13:16:
Use Windows XP SP3 compatibility mode
Reply 271 of 296, by Speedwarrior956
BEEN_Nath_58 wrote on 2024-11-06, 17:22:
I've did it already. To no avail....that is.
BTW I have it updated to v1.01 but it appears to happen on the vanilla build as well.
Reply 272 of 296, by BEEN_Nath_58
Speedwarrior956 wrote on 2024-11-06, 21:27:
Hm looks like the sound is consistent here now, I don't know what fixed it after a WinXP compat mode. Maybe try a different FMOD
Can you share the patch?
Reply 273 of 296, by Speedwarrior956
BEEN_Nath_58 wrote on 2024-11-06, 22:00:
Sure. I've just posted it @ Google Drive (Originally hosted @ The Patches Scrolls' old & current sites)
https://drive.google.com/drive/u/1/my-drive?q … lsier2dH8Uk9PVA
Just copy-and-paste it into the main game folder and run it as administrator.
Wierdly enough, PCGWs entry for this one doesn't mention this glitch..... #Suspicious
Reply 274 of 296, by BEEN_Nath_58
Speedwarrior956 wrote on 2024-11-07, 00:40:
The link brings it to your own GDrive, anyways I got it from Patches Scrolls.
The only difference I saw was able to exit the game with Esc key. However the problem still remains "fixed" in my end by whatever tha fixed it
Reply 275 of 296, by twiz11
BEEN_Nath_58 wrote on 2024-10-05, 06:46:
i know scummvm can play macromedia director files and quicktime embedded. try and run a director file in scummvm
Reply 276 of 296, by HeadacheGame
"NBA Power Dunkers for Windows 95 - NBAパワーダンカーズ for Windows 95"
This is a rare Japanese PC port of the Psx game that wasn't found until last year, but it seems to work in nothing:
DxWnd in Windows 10: Crashes / Freezes / Black Screen
Vmware,Virtualbox SoftGPU + Windows 98: Crashes / Freezes / Black Screen
3dfx voodoo + Japanese Windows 95,98 in Pcem,X86Box,Dosbox: Crashes / Freezes / Black Screen
I don't even care about the game, i'm just fascinated why the heck it doesn't run in any setup, it's not a powervr card game, but I wonder if it was coded for a very specific card and if someone feels like debugging why this game is so problematic.
Thanks in advance.
Reply 277 of 296, by BEEN_Nath_58
HeadacheGame wrote on 2024-12-18, 01:32:
"NBA Power Dunkers for Windows 95 - NBAパワーダンカーズ for Windows 95" […]
Thanks in advance.
On my Win7, the game hits a single exceptions and crashes. I will check more
Reply 278 of 296, by BEEN_Nath_58
Thanks in advance.
Works now:
https://github.com/narzoul/DDrawCompat/issues/415
I was too adamant to try the CD D3DRM.DLL (like most others I think)
Reply 279 of 296, by HeadacheGame
BEEN_Nath_58 wrote on 2024-12-20, 06:42:
Works now: https://github.com/narzoul/DDrawCompat/issues/415 […]
Thanks in advance.
Works now:
Thank you very much!, may you have a merry christmas and a happy new year 😀
