Reply 2600 of 3174, by digistorm
If the goal is preservation, it would maybe be better to preserve the original GUS (GF1 chip) because that one is more essential to run demo’s. And maybe reimplementation would also be a good idea because Interwave chips will not be around forever.
Reply 2601 of 3174, by elfoam
digistorm wrote on 2021-07-04, 13:32:
Yes I think the ultimate goal would be a fpga version of the GF1, hopefully one day someone with the talent and interest can do this.
Reply 2602 of 3174, by kdehl
Stiletto wrote on 2021-07-01, 23:10:
http://hackipedia.org/raw/Computer/Platform/PC,%20IBM%20compatible/Sound%20and%20Music/Advanced%20Micro%20Devices%20(AMD)/Interw […]
kdehl wrote on 2021-07-01, 21:01:
Does anyone have more information on the Am78C201 besides the simple pinout document that can be found everywhere. I have seen references to some Programmer's guide as well. And other documents I should be aware of?
http://hackipedia.org/raw/Computer/Plat ... on%202.pdf
The Interwave DDK (Driver Developer's Kit) and SDK (Software Developer's Kit) are also in the wild.
https://www.alsa-project.org/files/pub/manual … /gus/iw_ddk.zip
https://www.alsa-project.org/files/pub/manual … us/iw_sdk20.zip
I think that's about it, but it's been a while since I looked.
That was incredibly helpful. Thanks a lot!
Reply 2603 of 3174, by kdehl
elfoam wrote on 2021-07-04, 12:37:
Alright, I suppose not. I started designing my own board.
I'm not sure what type of board you plan to do (which ram etc) but the Gravis deserves to be an available card and open hardware with files that can be developed further. I feel like this is an important thing for the future of the demoscene and preservation. These photo's of the Gusar clone might help you along the way. I wish I had the original Philips board to scan but I don't (yet, am trying to buy one) right now none of the clone can be bought. so.. go forth
https://drive.google.com/drive/folders/1z6dDm … R8s?usp=sharing
Hi and thanks! This might actually be something that I could work with.
Reply 2604 of 3174, by elfoam
kdehl wrote on 2021-07-08, 20:55:
No problem, I hope they are good enough, let me know if not. The board (and photo) is 163.9mm x 100. If you get your design done and on github let me know also, it would be great to see it out there.
Reply 2605 of 3174, by matze79
keropi wrote on 2021-07-02, 05:13:
Didn't some russian guy already made GUSAR that was basically an IW card initially cloning Argus and then moved to their own design?
Isn’t it Still the same design ?
Reply 2606 of 3174, by elfoam
matze79 wrote on 2021-07-08, 23:18:
He has the GUSAR light which seems to be much the same as a Philips card I've seen. But yeah we are several clones deep by now. The problem is you can't actually get hold of any of them.
Reply 2607 of 3174, by kdehl
Hey, do you have the BOM to these boards as well? And if you could take even more high-resolution images of the boards, that would be great. It's quite hard to see some of the part markings.
David
Reply 2608 of 3174, by kdehl
elfoam wrote on 2021-07-08, 23:03:
Don't matter the images, they are good enough. But what about the Bill of Materials? Do you have that too?
Reply 2609 of 3174, by elfoam
kdehl wrote on 2021-07-24, 10:33:
The BOM is already mentioned in this thread plenty of times, here's the link http://bit.ly/2Ddf89V. I can help you with close ups of some numbers on the board if you can't make them out.
Reply 2610 of 3174, by kdehl
elfoam wrote on 2021-07-24, 16:16:
That's the BOM for the Argus, not the Gusar, isn't it? Or is the Gusar just a subset of Argus so that the BOM applies to Gusar as well?
Reply 2611 of 3174, by elfoam
kdehl wrote on 2021-07-24, 18:37:
They are both clones of the original and each other
Reply 2612 of 3174, by kdehl
elfoam wrote on 2021-07-24, 20:32:
Aha. I thought the Gusar was a smaller version of Argus. My bad.
Reply 2614 of 3174, by Thermalwrong
eeguru from the vcfed forums is actively making just such a thing. You can have a look here for more info, the video is pretty long but interesting. :
https://www.schrankmonster.de/2019/10/15/one- … -rule-them-all/
It's gone rather quiet on that front though.
I'm finally getting my own card courtesy of someone on ebay selling this for a reasonable price. I never thought I'd find one. This thread has been great for figuring out how I could put 2MB of RAM on there instead of the currently empty 512KB RAM footprint. Really hoping it gets here in one piece and actually works:
416.61 KiB
soon...
Many thanks to shock__ for sharing some of the prototype pictures - this one here confirms that it's possible to get a 42pin soj working on the 40pin footprint as long as those extra address lines are hooked up without shorting VCC/ground:
153.34 KiB
It's kind of rekindled my interest in having a go at making my own one though, the chips can still be had internationally for about $20. There's enough info in this thread for the now no-longer-available gusar to have been made to a reasonable standard. Personally I'd like a combo OPL3-SAx & GuS if it's possible, kind of like a Gus extreme. With the pin density of the SMD chips, it would be worth learning how to use solder paste + stencil.
Also there are now quite a few cards I can look at for reference that aren't a GuS, there's this cool 8-bit ES1868 sound card: https://github.com/hkzlab/ES1868_ISA8 and some PC104 implementations of the later 'all-in-one' ISA soundchips like this one that rasteri shared after making one for his tinypc build 😀 : Open Source PC104 Soundcard
Reply 2616 of 3174, by 640K!enough
terryfi wrote on 2021-12-04, 00:31:
Hello everyone, I am new to the topic; I couldn't follow the discussion about availability of PCB. Can anyone clarify if a new batch of PCBs are in production or for order?
As far as I'm aware, the plan is to have a batch for previous donors/contributors first, which has yet to go ahead. Then, there may be more available generally (not for previous donors) afterwards. However, it is unclear if either is still planned, or if the project has been shelved indefinitely.
Reply 2618 of 3174, by terryfi
Of course there is a demand for GUS. While I understand the project supporters should take priority; it is just matter of time someone else copy or do a new layout. As long as there is demand there will be some supply.
Reply 2619 of 3174, by Dr.Yak
Saddly, given my crappy soldering skills, I myself can't do much but buy already surface-mounted boards (and perhaps only do the last few through-hole component myself).
I can only support such projects mostly with my wallet, but would gladly buy a couple a unit or two if new boards are produced.
