Reply 26380 of 27685, by StriderTR
Been working with the PicoMite VGA I built myself for the past couple days. Very cool little project, easy, cheap, and fun to play with! 😀
It's a pretty versatile little "retro computer" anyone can build if you're into such things like I am, all open-source. I'm teaching myself MMBasic, really brings back memories!
https://geoffg.net/picomitevga.html
download/file.php?mode=view&id=182519
    558.02 KiB
Retro Blog: https://theclassicgeek.blogspot.com/
Archive: https://archive.org/details/@theclassicgeek/
3D Things: https://www.thingiverse.com/classicgeek/collections
Reply 26381 of 27685, by HomeLate
Working on an Olivetti M24. I don't have a compatible monitor but an IBM MDA works fine without disabling the onboard GO318 graphics.
I removed the Varta which did its job on the mainboard. Corrosion is minimal, but the speaker is gone. The powerled is missing but that will be replaced too.
So far it boots fine. The floppy drive needs some work. Unfortunately the original MFM hard drive is gone. That will be replaced with XT-IDE.
403.03 KiB
Reply 26382 of 27685, by gerry
StriderTR wrote on 2024-01-10, 07:55:
Been working with the PicoMite VGA I built myself for the past couple days. Very cool little project, easy, cheap, and fun to pl […]
that's a really interesting project! i read the link and its a nice way to 'create' a classic 80's style home computer
Reply 26384 of 27685, by dominusprog
DerBaum wrote on 2024-01-10, 12:51:
PC104 things...
Why not use a slot?
Aztech Pro16 II-3D PnP ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 26385 of 27685, by DerBaum
dominusprog wrote on 2024-01-10, 13:03:
PC104 things...
Why not use a slot?
i am testing the inner workings of pc104 to make my own cards.
How PNP works... if i can re assign irqs in hardware, if it works in 8-bit mode... and so on.
Its much simpler to measure and reconfigure pins this way.
The card i used is just a soundcard that will be turned into parts for this project. so it doesnt really matter if the isa connectors are full of solder.
FCKGW-RHQQ2
Reply 26386 of 27685, by dominusprog
DerBaum wrote on 2024-01-10, 13:06:
i am testing the inner workings of pc104 to make my own cards. How PNP works... if i can re assign irqs in hardware, if it works […]
PC104 things...
Why not use a slot?
Good luck with your experiments 😀
Reply 26387 of 27685, by PcBytes
First, I took out another great board that was already recapped, from the storage, to prep up for sale likely.
It's a Zida 6DLX, w/ a 266MHz SL2HC that I suspect is a unlocked chip - it POSTs just fine at 333, but I haven't tried any higher than that.
file.php?mode=view&id=182578
file.php?mode=view&id=182579
file.php?mode=view&id=182580
Also took some time to revamp a old and derelict Radeon 9550 256MB.
I'd gladly flash this card to a 9600 if I had the right BIOS for it.
file.php?mode=view&id=182581
file.php?mode=view&id=182582
The barren card next to it is also a 9550, except 128MB, and which was unfortunately artefacting.
It's a bit funny, since that one uses classic DDR while this 256MB card uses DDR2.
Reply 26388 of 27685, by BitWrangler
I don't think they started locking PII until the 300+ was out and there were remarkers active, selling 233 or 266 as 300. The Klamath core doesn't generally like much more than 300 stable, there's a handful that do 333 stable when loaded/stressed. Most were cherrypicked by intel for the higher speed releases, but because they weren't scaling much Deschutes became necessary.
Reply 26389 of 27685, by appiah4
Interesting I did not know this; I only thought VERY early PII 233/266s were unlocked and therefore not available in significant volume..
Reply 26390 of 27685, by BitWrangler
Might have seemed very early to anyone outside US because of unobtanium pie in the sky prices, so when they hit actual home town computer retailers they were either locked very shortly after or arrived locked.
Reply 26391 of 27685, by BetaC
Today I spent about an hour getting an IBM PS/2 Model 80 ready to be sold at my local recycler. It took so long because I had to make a floppy to reset the CMOS after spending $15 on a battery. It managed to only lose 32KB after formatting the huge 42MB drive it came with, and was otherwise in pretty great condition.
Reply 26392 of 27685, by PTherapist
Bruninho wrote on 2024-01-09, 17:25:
chrismeyer6 wrote on 2024-01-09, 13:24:
My dad bought a copy of 2000 on launch day and he promptly installed it on the family computer in a dual boot setup with 98 SE. That system never felt faster and was nearly perfectly stable. Any of mine or my siblings games worked just fine we rarely need to use 98. We used 2000 untill we got a copy of XP Pro in 2004.
I share a similar history.
The only game that failed on Win 2000 was FIFA 2000, I believe mainly because of SecuROM issues. To this date, even in Win 2K VMs the game fails to start. But runs fine on XP and 98. *Shudder*
FIFA 2000 works great on Windows 2000 if you use a no CD crack. Piracy to the rescue. 🤣
Reply 26393 of 27685, by PD2JK
Removed all 29 orange tictacs and put some Panasonic electrolytics on. Test drive went well, next up is to mod or replace the ST TimeKeeper™RAM.
1.69 MiB
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Orion 700 | TB 1000 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 26394 of 27685, by dominusprog
Work is kind of finished.
705.35 KiB
603.65 KiB
730.48 KiB
572.15 KiB
Reply 26395 of 27685, by PcBytes
Preparing my Zida 6DLX for a local sale.
Equipped it with a Celery @ 433MHz, 128MB SDR, a 10GB drive out of a OGXBox, GF4 MX4000 64MB, CT4810 soundcard.
Running 3DMark99 at this moment, it's pretty smooth. Lemme know if y'all interested to see the score it puts out.
Reply 26396 of 27685, by Nexxen
PD2JK wrote on 2024-01-11, 15:36:
Did you record such fun and put it out on YT? 🤣
Must have been tedious, I say. 😀
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 26397 of 27685, by PD2JK
Nexxen wrote on 2024-01-11, 16:45:
Haha. No. 😜
I like to make a fool out of myself, but to put it on YouTube is a bridge too far.
Reply 26398 of 27685, by 7F20
PD2JK wrote on 2024-01-11, 17:04:
is there a reason you chose electrolytic? I typically just put film caps on there so I don't have to think about leaking.
Reply 26399 of 27685, by Nexxen
Haha. No. 😜
Just for the time it took and the dexterity displayed I'd go with an applause and a very nice pat on the back.
I like how it came out and it even looks a little more modern.
Personally I dread it as it is time consuming and so much "the same" making me prefer house chores. 🤣
