Reply 26540 of 27689, by PcBytes
gerry wrote on 2024-01-26, 08:41:
PcBytes wrote on 2024-01-16, 19:11:
Finished painting it! Green and white, goes pretty well. Doesn't look the best as the place I used to buy paint from recently switched to crappy chinese-made paint.
looks cool, kinda military almost 😀
Ahahah 🤣 thanks. Now, to order a Aladdin XT and maybe go to town with programming its CPLD as well.
Reply 26541 of 27689, by iraito
Minutemanqvs wrote on 2024-01-26, 12:49:
What are the specs written on your RAM chips, so we can see what their theoretical maximum speed is?
Here's the ram and also the final result.
If you wanna check a blue ball playing retro PC games
MIDI Devices: RA-50 (modded to MT-32) SC-55
Reply 26542 of 27689, by Trashbytes
iraito wrote on 2024-01-26, 14:17:
looks like 7 nano second ram so 143Mhz, 6ns is 166Mhz and 5.5ns is 183Mhz, this is of course their rated speed but in theory with good cooling should be able to run a bit higher.
These speed match up with the Vram speeds of the different models, its possible to find V3 3000 cards with 5.5Ns ram not sure if any V3 2000 had it.
Reply 26543 of 27689, by iraito
Trashbytes wrote on 2024-01-26, 14:21:
looks like 7 nano second ram so 143Mhz, 6ns is 166Mhz this is of course their rated speed but in theory with good cooling should be able to run a bit higher.
Yep looks like it, should the overclock to 166 still be relatively safe ?
Reply 26544 of 27689, by Trashbytes
iraito wrote on 2024-01-26, 14:24:
Depends on the ram itself, I would increase it in 5Mhz increments till it starts to artifact and then dial it back by 1Mhz steps till its stable, good quality 7ns Vram should be able to handle a decent speed bump, might even get to 166 stable.
You can then do the same with the Core, that cooler is silly levels of overkill but at least the core will be nice and cool !
Im pretty careful when OCing my Voodoo cards, they are too damn expensive to replace so normally I give them a small bump and leave it at that you really dont get a lot out of the extra speed.
Reply 26546 of 27689, by Trashbytes
rasz_pl wrote on 2024-01-26, 14:30:
Other than ram 3dfx also overvolted higher numbered models https://www.youtube.com/watch?v=Sk7rpPmhykY
Interesting topic for the brave out there willing to mess around with their cards 🤣, im guessing it not really something the average joe would want to do.
Reply 26547 of 27689, by iraito
Sounds like I will try going up to 3000 levels, by reading around it seems like every 2000 with my ram can go up to that with no issue whatsoever, then they start artifacting at around 183hz
Reply 26548 of 27689, by appiah4
I finally found the time to have one last go at fixing this A-Trend ATC-1762 VLB motherboard.
613.32 KiB
I started trying to get it working exactly one year ago, and got it done on the anniversary! It was a long repair that saw me having to replace the KBC socket and bodge a lot of traces because battery leakage completely ate them. Then I had to replace tantalum decoupling capacitors that decided to end their lives with a bang. Then the BIOS chip on the board turned out to be from another board entirely, so I replaced that. Finally, I had to invest into an oscilloscope to figure out my final keyboard related issues were due to a defective 7406 and replace it. All in all, it was an adventure, but I like a happy ending. It will never look as good as new, but this spaghetti mess is my only spare VLB board and a keeper 😀
579.67 KiB
737.19 KiB
Reply 26550 of 27689, by TheMobRules
appiah4 wrote on 2024-01-26, 19:37:
Nice fix! VLB boards are probably my favorite along with EISA due to all the quirks.
By the way, you may want to tin those exposed traces, otherwise the bare copper may start to corrode.
Reply 26551 of 27689, by overdrive333
Voodoo 3 1000 conversion to 2000.
heatsink, voltmod (2.2v->2.7v. However, 2.5v must be enough) , bios.
Reply 26552 of 27689, by iraito
overdrive333 wrote on 2024-01-27, 10:57:
Did you solder the extra mem yourself? i thought a velocity with more than 8mb of ram was never officially released.
EDIT: Are V3 1000 another thing unrelated to velocity cards? damn 3dfx what a mess they did.
Reply 26553 of 27689, by Demetrio
This morning I went to a pick-up point to get the italian version of Half-Life 2: Raising The Bar
88.63 KiB
HL2: Raising The Bar IT
I bought it from a local seller for 40€.
Considering that the only insertion I saw, other than this one, is on Amazon for over 300€ and that the italian version is very rare, I think I made a good deal 🙂
Reply 26554 of 27689, by Horun
Demetrio wrote on 2024-01-27, 12:49:
This morning I went to a pick-up point to get the italian version of Half-Life 2: Raising The Bar […]
Oh yes, some language versions of some games are very rare. Nice find for you !
Reply 26555 of 27689, by Horun
Good job !
Reply 26556 of 27689, by Trashbytes
iraito wrote on 2024-01-27, 11:15:
There were a number of Voodoo3 1000 cards with 16Mb and they are separate from the V100 8Mb and V200* 12Mb Velocity cards, V3 1000 is just a low cost Voodoo3 2000, its got lower clocks 125/125 to the V3 2000 and no heatsink and uses lower cost parts, uses double the memory ICs but they are low cost SGram
If you throw a heatsink and fan on a 1000 it should hit 2000 speeds with little issue.
*This one never saw release officially.
Reply 26557 of 27689, by Ensign Nemo
Horun wrote on 2024-01-28, 03:58:
Isn't that a book?
Reply 26558 of 27689, by Ensign Nemo
The used book market is often worse than the eBay market for vintage computers. Your book is listed at $465 on Canadian Amazon. I sometimes see guys in thrift stores that are scanning all of the books with their phone to see if they can scalp them. That really ticks me off because a lot of low income people shop at thrift stores to save money.
Reply 26559 of 27689, by Trashbytes
Ensign Nemo wrote on 2024-01-28, 04:39:
Scalpers are a fucking plague, not sure how you would go about stopping such activity either.
