Reply 2760 of 30408, by Oldbitcollector
Finally convinced the owner at the recycling center to watch for old Super Socket 7 boards.
(The ones that have both the ATX/AT, 72pin/30pin memory combination with AGP socket)
Found one with a AMD K6-III-450 that posted once I pulled it out of the worst mounting I've ever seen in an old case.
Posted perfectly and set aside for EBay sometime in the future.
Another board saved from destruction. 😀 Someone will get a neat system from this.
Reply 2762 of 30408, by kithylin
HighTreason wrote:
Playing around with a GM map on my Korg. Would anyone be interested in hearing how the O1 sounds in a few games?
I'm not sure what the Korg is, but I assume some sort of MIDI thing. So yes I'm interested in hearing MIDI music from games on different MIDI gear. Make a thread about it somewhere and either PM me a link or reply here with a link to it.
Reply 2763 of 30408, by Oldbitcollector
Dropped a Audigy2zs into my dual core XP box today to play with some soundfonts and midi files.
Reply 2764 of 30408, by Oldbitcollector
kithylin wrote:
I would!
Reply 2765 of 30408, by CelGen
Been chasing with an 8" floppy drive all weekend. Stepper circuit isn't working right because he reset bus is stuck. Getting close to tracking the fault down but damn if it's not annoying without a schematic.
Reply 2766 of 30408, by idspispopd
Skyscraper wrote:
Im trying to use a 20 year old HP 2x CD-RW disc with a Samsung Blu-Ray/DVD-RW... Not a great success so far, the Samsung drive really really wants to burn the disc at 48x speed which the disc of course cant handle... Perhaps if I do the full wipe 10 times in a row first...
I think I remember something about there being a significant distinction between CR-RW <= 4x and higher speeds. AFAIR those are just not compatible. Just use those old discs with an old drive and new discs with a newer drive. This has also been my personal experience, but that was only with one batch of 2x CD-RWs.
The Wikipedia article on CD-RW says something different.
I think it's probably not worth the trouble.
Reply 2768 of 30408, by Skyscraper
Yesterday I binned the 27x P200 CPUs I bought two weeks ago.
Using a PC Chips M577 MVP3 motherboard 7 of 27 were able to boot DOS at 3x83 = 250 MHz (PCI=33MHz as the board supports a 2.5 divider) but none could run Windows 98 even if a few came very close. I did also test those 7 CPUs at 2x100 MHz but not a single one of them were flawless at 100 MHz FSB. I tried a Pentium MMX at 2.5x100 MHz just to make sure this spare motherboard could still do 100MHz FSB and sure enough it worked flawlessly at stock voltage.
The conclusion is that the P54C Pentium 200 is a very poor clocker but I have at least found some candidates for my two i430FX motherboards, 3x80=240 MHz seems very possible.
Today Im going to test my 30x new P233 MMX CPUs to see if I find one that will do 3x100 MHz at less voltage than my current best Pentium MMX.
Reply 2769 of 30408, by 386_junkie
Interesting... i've just repaired an IBM PS/2 3.5" floppy drive. Now i've been looking to get a hold of an 8" drive, but I see none are working so it would be another repair job / project in itself.
Reply 2770 of 30408, by Tetrium
No!! 😢
You threw out 27 P-200 non-MMX chips? These were never good overclockers, Intel had trouble producing enough that could run at that speed.
With the 233 MMX it's different as Intel sorta purposefully didn't want to see higher-clocked MMX chips for s7 as this would hurt their P2 sales...or something like that. They could've been factory-clocked higher, it's probably why those are a lot easier to overclock.
Intel could have sold these at higher clock rates but Intel chose not to do so.
My retro rigs (old topic)
Report spammers here!
Reply 2771 of 30408, by Skyscraper
Binned as in speed binning* them! 😀
Im not throwing out any working CPUs, not even Netburst Celerons!
*Sorting CPUs in different "bins" depending on their capabilities.
Reply 2772 of 30408, by Tetrium
Thank god 🤣!
Reply 2773 of 30408, by CelGen
8" drives are from another era relative to DOS/Windows so getting them to work even with machines in the late 80's was weird. I've heard stories of getting some models working with an adapter board (they aren't 34 pin) and finger crossing but typically it was for using programs like imgdisk to archive or create new diskettes for other machines.
Reply 2774 of 30408, by 386_junkie
When you say adapter board... you mean, floppy disk controller? I'm sure there were 8-bit ISA cards that had a compatible IDE-type port to communicate with the drive?
Reply 2775 of 30408, by HighTreason
Trying to ready my benchmarking suite for release. Trying to mend a bug in the menu which skews the results. Turns out it might not be a bug as I tried again and found that the bug then went in reverse, implying it is just fluctuation in DOSBox, I do test on the real hardware before fully committing anything anyway and guess I will have to do that again now.
I do plan to make a small optimization to system memory though, as I had something eating a few KB before which might have lowered scores, this is simple to remove but requires clearing the screen at a certain time - luckily, the screen is blank already at this point so the end user won't notice much of anything unless they have a slow machine, in which case they might see a quick blink of text on their display.
EDIT: But maybe don't use the FDIV Pentium and Quake to test as that system is prone to occasional Divide overflow's in Quake when it switches demo. Looks like Pentium OverDrive will save the day again... Or maybe I'll use Doom, given I went to the trouble of raking out the "Theme music" for the Pentium, plus I really like this machine right now.
The attachment vlcsnap-1198-01-25-06h09m15s164.png is no longer available
Also sick of my workstation and my laptop silently switching me to UK keyboard layout, sure, I live in the UK, but I use US International keyboards where possible as I much prefer the layout and the ability to type umlauts and whatnot.
Edit 2: Indeed, the problem is non-existent on the real hardware. Though the optimization still wouldn't go amiss because not every machine is going to have 64MB of RAM to throw at it, I can't really see eating 2-3K of conventional doing much but as I can free it up prior to running anything and just reload the TSR before bringing the menu back up it is probably worth what little effort will be involved.
Reply 2776 of 30408, by SquallStrife
The connector is different, but the interface is mostly the same. http://www.classiccmp.org/dunfield/img54306/cnct.htm
Reply 2777 of 30408, by 386_junkie
I like it, that's my kinda mod... yet another project in the midst!
Reply 2778 of 30408, by Malvineous
There is also the FDADAP which lets you connect 8" drives to a standard PC floppy bus. I used this to connect an 8" drive to a Kryoflux and I was able to image some 8" disks successfully.
If you're looking for an 8" drive, the key seems to be to get one that matches your local utility power - e.g. 240V 50Hz. For some reason many were made for 60Hz at voltages used in 50Hz countries and vice-versa, so you might get one that matches your local voltage but chances are it will be for the wrong mains frequency. This will cause the motor to run at the wrong speed making disks unreadable (seems this is why the drives show up on eBay - buyers realise they won't work and then on-sell them.)
Reply 2779 of 30408, by idspispopd
Which OS?
You are probably hitting Alt-Shift accidentally without any other keys. The default behaviour of Windows for this combo is to switch keyboard layouts.
You can either remove the UK keyboard layout, or just turn off the hotkey if you still need the UK layout occasionally.
The setting is not hard to find, either in the control panel (exact location depends on the version of Windows), or you can go there with the corresponding icon in the systray if there is one (might say "EN" or "UK", probably blue background).
