Reply 280 of 924, by Pickle
elfoam wrote on 2023-04-16, 19:45:polpo wrote on 2023-04-16, 16:36:I need to improve the instructions for that as they’re mostly wrong because I went by memory. In the installer, choose the option to extract the files to C:\ULTRASND instead of going through setup. And then you can set the ULTRASND and ULTRADIR variables in your autoexec.bat file manually.
Thanks I got it to work, I went to the section called restore files and put *.*
I'm trying to get both it and a sound blaster working together now and make adlibtracker behave at the same time.. This is part of DOS I don't like to remember.
just make sure your address, irq, dma are different. Im running two cards and ill use 220,7,1 240,5, 3. If can use unisound you can manage it with the set blaster.
