Reply 28720 of 31379, by 386SX
The battery door missing plastic leg, a common problem of these cameras.
Reply 28721 of 31379, by lti
I was running my Gateway Solo 2500 yesterday, and it lost its backlight. I don't have the energy to do much hobby stuff right now, and I'm going to spend a lot of my free time getting in better shape. I will have to fix it eventually, but it will be to keep other old stuff running instead of gaming.
Major Jackyl wrote on 2024-11-09, 20:58:
Hmmm. Tested a "broken" card before taking the heatsink for the working one (6600 AGP). What is this?! It crashes at POST, but always works; would a BIOS flash possibly fix this thing?
With the artifacts and incorrect characters, I would guess that it has bad video RAM or bad BGA soldering. Those aren't easy to fix with hobby soldering tools.
386SX wrote on 2024-11-10, 15:43:
the great Canon A70 (great camera but on a fragile zoom mechanism)
Was that one of the models that had a defective CCD? I remember the A60 being recalled because that was my parents' first digital camera. Its CCD failed after the repair period expired.
Reply 28722 of 31379, by 386SX
lti wrote on 2024-11-10, 17:13:
I suppose the A70 probably had the same problem but it didn't happen to my unit or maybe I think it happened more on the A60 but still I remember anyway that maybe the Digic processor and/or the camera CCD sensor may have had problems reading forums messages later. But at that time I was thinking the zoom mechanism would have died at any time considering the noise it did and it didn't felt much fixed/stable on its rails. But the camera itself resulted in great 3MP images, very detailed and with nice clear colors. In its time it was a bit expensive but I was reading most positive comments after their releases.
Reply 28723 of 31379, by darry
darry wrote on 2024-11-10, 14:39:
That was my first "real" digital camera (S5200 is the North American model) after 2 or 3 years of using an Olympus D560 Zoom. My […]
386SX wrote on 2024-11-10, 12:24:
Today I repaired an old 2006 second hand Fujifilm S5600 camera using a second not working unit. Had to only change the internal battery plastics/cover but unfortunately I've broken a button metal pin from the inside of.the working one and had to switch all the hardware into the second unit (when I was supposed to do the opposite) whole optic included. A painful work in such compact case space with flat cables and old fragile components. Now at least one unit is fully working and with a just bought brand new 512MB memory card quite expensive too. This camera is interesting cause one of the early Super CCD sensor based cameras from Fujifilm, an interesting concept discontinued after various versions a decade ago. Of course not great compared to nowdays standards but still has a good optic (F2.8>3.2 at 10X zoom).
That was my first "real" digital camera (S5200 is the North American model) after 2 or 3 years of using an Olympus D560 Zoom. My mother still has that S5200 . It's in a box somewhere. I need to ask her about taking it for a spin again after all this time. Hopefully, the coin cell hasn't leaked.
EDIT: Those 🤣 cards sucked, speed wise, especially the slower M variants, AFAICR. RAW was painfully slow, AFAICR. Not sure if the faster H variants actually were faster in the S5200 (or if they even worked, they might have required s firmware update). Anyway, this is all stuff you probably already know or can still find in the Internet.
I wonder what drew you to this camera in the ccurrent day and age? Was it something you used back in the day ? Fascination with SuperCCD ?
EDIT2: AF speed and accuracy was very good in decent light, for uts time, AFAICR. I am really starting to miss this thing. As, I have archives of all the photos I've taken, I might just have a go at reprocessing some RAWs. DXO Pureraw does not support this, so I will have to rely on RawTherapee and NeatImage.
The 512MB card I've bought is an H variant and I've read even the 2GB version might actually work, probably depending on the camera firmware indeed. Maybe not officially I'll see to find one. On the speed size it doesn't look much fast but of course we're used to modern Micro SD speed; I imagine just a bit faster than the slower ones like the original 16MB sold with it. I suppose the various interesting IC processors running on the main PCB may be also limited, it never felt much fast like the zoom speed on the internal gallery app while decoding a full resolution image.
I knew about this digital camera because in the early 2000 I bought many other ones from the cheapest Trust early VGA cameras to the great Canon A70 (great camera but on a fragile zoom mechanism) and ended up to the Fujifilm S5500, the previous 4MP standard CCD version that many were talking really good about and I bought it at release brand new (quite expensive too), I still have that one fully working. After a while I remember reading about this new Super CCD tech and at that time on paper it looked like the future and a smart way to get more data captured on a compact camera sensor like these. So I wanted to buy the S5600 but still it wasn't that much different from the S5500 to buy it so I didn't. I've bought the first working unit a week ago in a second hand retro store; it only needed to fix that battery door which seems quite a known problem on both the S5500 and 5600 projects where plastic will eventually break given the force the four AA batteries will push and at the end I've broken the main silver button pin removing that internal battery case.
Glad you're giving it a new lease on life. I really loved my S5200. My main reason for "upgrading" was the desire for adding a flash . The S9000 I replaced my S5200 unit with never felt as stable in my hands, had more iffy focus and the lens felt softer . It was still a good camera and I did get some nice shots out of it, but it felt like a letdown after the S5200. RAW writing speed sucked with both CF and 🤣 cards on the S9000, AFAICR.
I hope a more permanent and durable solution to the brittle plastic problem will be found.
Reply 28724 of 31379, by Postman5
Hi,
What do you think about this handmade cooler 80x80x10 for Voodoo3 video cards?
Reply 28725 of 31379, by Repo Man11
Postman5 wrote on 2024-11-10, 18:29:
Hi,
That takes me back to what I rigged up back in 2002 to allow me to overclock my Ti 4200 a little bit.
Reply 28726 of 31379, by 386SX
darry wrote on 2024-11-10, 17:51:
I'm glad you told your story about this camera, thanks. A friend had the S9000 and it felt so much better on paper but was expensive and I had lost a bit of interest in spending too much upgrading digital cameras at that time. The whole Super CCD tech indeed was the main subject of interest for Fujifilm cameras at that time.
Reply 28727 of 31379, by Major Jackyl
The re-cap job on the K7S5A went smoothly. About to be testing this again today and assembling it into a system.
Oh yeah!! Looking good!!
The attachment 20241110_140147.jpg is no longer available
The pile of old caps: There were 60 total.
The attachment 20241110_140320.jpg is no longer available
Main Loadout (daily drivers):
Intel TE430VX, Pentium Sy022 (133), Cirrus Logic 5440, SB16 CT1740
ECS K7S5A, A-XP1600+, MSI R9550
ASUS M2N-E, A64X2-4600+, PNY GTX670, SB X-Fi Elite Pro
MSI Z690, Intel 12900K, MSI RTX3090, SB AE-7
Reply 28728 of 31379, by StriderTR
Picked up a couple cheap internal CF/IDE adapters to use as internal storage drives in both my DOS and Win95 machines. My primary on both are SD/IDE adapters, accessible from outside the case for easy swapping like many people use these days. I just wanted something internal for backups or extra file storage, and I still had these two 2GB CF cards lying around. Tested everything today, all works perfectly.
DOS, Win9x, General "Retro" Enthusiast. Professional Tinkerer. Technology Hobbyist. Expert at Nothing! Build, Create, Repair, Repeat!
This Old Man's Builds, Projects, and Other Retro Goodness: https://theclassicgeek.blogspot.com/
Reply 28729 of 31379, by VLIW
Installed XP on an old Asus X50n notebook that was headed for the recycler (AMD Turion 64 and Geforce 7000M). Not too bad for W98-era games.
Reply 28730 of 31379, by Babasha
LPX case revoring and more... gradient coloring 😉
The attachment IMG_1390.jpeg is no longer available
The attachment IMG_1391.jpeg is no longer available
The attachment IMG_1392.jpeg is no longer available
The attachment IMG_1393.jpeg is no longer available
Need help? Begin with photo and model of your hardware 😉
Reply 28731 of 31379, by BitWrangler
Hi,
Looks like it does the job.
Personally though, I like to give "Murphy" the imp of the perverse who names "Murphy's Law" less loopholes to work with, so I would be wanting to tie it to the drive cage or make a nonconductive plate that holds in the PCI slot so that it does not swing the fan into the card if the system is moved. Although I guess it might take a bit of a knock if that wire is rigid.
Reply 28732 of 31379, by bZbZbZ
Hi,
I highly recommend these <$5 brackets which allow you to more securely mount case fans to a PCI bracket:
https://www.aliexpress.com/item/1005005868217402.html (I'm NOT recommending this particular seller, please shop around)
I'm using two 92mm fans to cool my Voodoo 3 3000:
First post - restored Pentium III & Athlon X2
Reply 28733 of 31379, by CMB75
Babasha wrote on 2024-11-11, 18:29:
That looks exceptionally good, nice paint job. I think I still have to practice a lot to achieve such a result.
Reply 28734 of 31379, by zuldan
bZbZbZ wrote on 2024-11-12, 05:30:
I highly recommend these <$5 brackets which allow you to more securely mount case fans to a PCI bracket: https://www.aliexpress. […]
Hi,
That’s the exact setup I have for all my V3 3000’s. Keeps them ultra cool.
Reply 28737 of 31379, by gmaverick2k
Delete
Typing on phone
"What's all this racket going on up here, son? You watchin' yer girl cartoons again?"
Main:z440/2699v3/RTX3060Ti/iFiZenDAC/T480 IPS
98:KT333/AthlonXp 2500+Barton/V3 3000/Vortex2/SC-55
DOS:SS7/P166MMX/V3 2000/PicoGus
XP:Edge72/3570K/GTX970/X-FiTi
Reply 28738 of 31379, by gmaverick2k
gmaverick2k wrote on 2024-11-12, 21:34:
Configuring my dos setup. Voodoo 3 2000 ago, Ess 1868f and picogus. Updated ga-5ax rev 4.1 bios from 1.3 to f4. SD to ide card was not being picked up so flashed bios and issues resolved. Had to use gotek with 98 startup disk then changed to bios flash disk.
Got an image of dos and oses and flashed onto SD card from the great archive organisation. Also got some dos disk images and tried out epic pinball and Duke 2. Sound ok. Also installed Norton commander 5.5 using gotek, pretty nifty piece of software
Waiting for pentium mmx 166 and k6-2+ 500 which still in the post so that I can replace the k6-2 500 non+ currently in there
Reply 28739 of 31379, by gmaverick2k
Delete
