Reply 29040 of 30585, by RetroPCCupboard
smtkr wrote on 2025-01-08, 03:16:Which drivers are you running. I have a similar setup and, while Deus Ex doesn't run great in outdoor environments, I definitely […]
Which drivers are you running. I have a similar setup and, while Deus Ex doesn't run great in outdoor environments, I definitely get 30-45 FPS in the first level.
I'm running
1GHz Pentium 3 (SL4KL)
512MB PC133
Geforce 2 GTSWindows XP SP1
version 5.32 (June 2000) under Windows 98 with 256Mb RAM. It's possible that something is wrong with the card, the motherboard or the config. 3DMark 2000 score is 6430, which I think is perhaps a little low. But certainly not half what it should be.
