Reply 29380 of 31416, by yourepicfailure
Cosmic wrote on 2025-03-12, 15:26:yourepicfailure wrote on 2025-03-12, 10:40:i dont know why but suddenly I feel the urge to understand the computers/code between these cameras... […]
i dont know why
but suddenly I feel the urge to understand the computers/code between these cameras...One of them has 8 whole bits of computing power,
while the other is... 4 massive bits. (HD63P05Y0 vs HD44860/HMCS47C)Whoa, that's a badass camera setup. Yeah, I have to imagine it's all custom firmware for these cameras or the line of them. Maybe there's a ROM somewhere that could technically be dumped and analyzed.
Do the cameras work, or any plans to try using them?
The cameras are both, now fully functional.
I found a replacement VCXO for the M7 (had to scrifice a "lesser" camera) so I suppose I should close out Options for a bad oscillator?
But yeah I do use them, the M7 is the one I use regularily. The M3a would love to see some use, but it's got vidicons so I don't bring it outside as often anymore.
However, had to put that one aside to finish fixing the tape recorder, Sony BVW-50, for them.
Wasn't fond of some of the maintenance performed on a few of the boards in the unit, in a lot of cases the previous engineer who worked on this simply goobered through-hole caps onto SMD pads.
Absolute nono to me. Caps were still good, but I slapped proper SMDs in their place.
The SST/main control board is the last one I haven't gotten to so I'm documenting and ordering caps for it.
Only 30 caps here that should go (a few leakers too) so much easier than the nearly 200 SMD electrolytics on the time-base corrector and video processor boards.
Only issue is I can't find that exact battery anymore (it reads exactly 0v) but I'm sure there are compatibles out there.
