Reply 2961 of 3317, by sharangad
Makus wrote on 2025-07-07, 07:45:
Hi sharangad,
are you talking about the INT 21 functions of the DOS/4GW extender?
Perhaps chapter 10 of this book can help you: https://openwatcom.org/ftp/archive/11.0c/docs/cprogguide.pdf
That's just what I need! Thank Makus! I would never have found that on my own.
https://patreon.com/Rready
Reply 2962 of 3317, by sharangad
Hi sharangad,
According to the pdf, Int 31h is the Dos4GW call. Int21h is a dos call which can be overridden by a user supplied 32 bit handler. So this call is probably internal to the app.
Reply 2963 of 3317, by sharangad
ICR2 makes several Rendition specific Int 10h calls as well as Int 1Ah calls to detect and initialise Rendition boards.
Going through the source in Ghidra there's only one int 10h call (function 0x0f: Get current VGA mode.) and not a single int 1A call. Is it safe to assume binary is a compressed dynamic loader? I thought it was but checkpoint10 at icr2.net was able to work out what the data blocks did and control engine and track physics.
If it does anyone know how I can decompress the rest? I tried using IDA (the last version compatible with DOS and it has rendering defects in my Win98 VM). In theory Ghidra should be able to do it.
Reply 2964 of 3317, by RaVeN-05
not sure , there is a lot of exe compressors. probably you can use dosbox debugger and dumpmembin 0:0 ffffff (bumps 16 mb ram file) while game runs , this will expand exe if its compressed and show code in uncompressed state.
for other things: i streamed vquake1
and have spot some differences to original HW, its minor and not matters:
r_antialias - works even if AA still early version , for value 4 or 7 which will use rounded particles its have little bug, particles sometimes have transparency problems like we seen earlier in vhexen2
see atachments
r_surfacelookup - ok
d_bilerp - turn off/on models (should off/on texture filtering)
d_sync - dead cvar, no attention here.
d_amip - 0 - makes model looks better, 1 - at distance models will use mipped image and bad side of it models will have blue lines at some connected polygons
d_wfreq - works (better than original HW) at some negative values we could see blue noise on original HW, here its not happening
d_wamp - works (better than original HW) at some negative values we could see blue noise on original HW, here its not happening
d_dither - off/on texture filtering (while it off/on color dithering on original HW to simulate more color depth)
the blue or noisy colors appears at world map geometry in connected surfaces/triangles
see atachments
when noclipping out of map boundaries
in wrapper - hall of mirrors and weapon model view is slowly whitening to solid color
in original HW - everything filled by gray clear color , even weapon is removed to gray too
the highest resolution in game crash game if menu or console invoked.
while underwater resolution can be used safely any resolution.
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 2965 of 3317, by sharangad
Thanks for the bug report. I was waiting for this a long while!
Raven-05, could you try this to see if the particle problem is fixed? I never noticed it before, but I tried shooting the CRT in slipgate complex and it seems ok now.
[EDIT] The other bug is probably a QSPAN or texturing bug, but most probably QSPAN. How does it run on your system?
[edit2]
Also it seems like vhexen2 is based on the vquake 1 code base.
[/EDIT2]
RReady Alpha, 07 July 2025
https://nirvtek.com/downloads/RReady.Alpha.20 … vQuake.Alpha.7z
MD5: 617dcb64b46ee64a2e081ea4e15c29a4
- Possible fix for vQuake particle transparency alpha blending bug.
Reply 2967 of 3317, by sharangad
RaVeN-05 wrote on 2025-07-07, 16:45:
works excellent!
That's a relief. I'll take a look at the other bugs tomorrow.
Is there a cvar to turn model rendering on and off?
Also I think the higher resolution problems with vQuake are pretty much the same as vhexen 2.
Reply 2968 of 3317, by sharangad
This should fix d_dither enabling d_bilerp and d_bilerp hiding models.
https://nirvtek.com/downloads/RReady.Alpha.20 … 8.002.vQuake.7z
MD5: 921c801df8ad5639e035d4b3c61f8f63
The texture seam problem is related to the QSPANs and texture clamping. Still looking at fixing it.
[EDIT] can't fix the qspan bug just yet. Getting my roof fixed over the next couple of days.
Reply 2969 of 3317, by sharangad
Ok, while I have some time. The stay coloured pixels are a scaling artefact. If the Rendition upscaling resolution is set to 1280x960 and vquake's resolution is set to 640x480, the lines disappear. The upscaling resolution needs to be an integer multiple of the game's internal resolution. Turning on "integer scaling" will also help.
I really need to do something about scaling artefacts. ICR2's cockpit dials also have the same problem.
Reply 2970 of 3317, by RaVeN-05
d_dither
d_bilerp
all fixed thanks, d_dither is have no valuable now coz everything rendered in 32 bit colors, which is better.
the dynamic lights in quake is painful, slowlyness is probably can be fixed in future by qemu but for now its most lowest priority. )
Thanks)
Reply 2971 of 3317, by sharangad
RaVeN-05 wrote on 2025-07-09, 10:43:
d_dither d_bilerp all fixed thanks, d_dither is have no valuable now coz everything rendered in 32 bit colors, which is better. […]
d_dither
d_bilerp
Thanks)
Thanks for testing all that. The dynamic lights are affected by r_surfacelookup. Try toggling the setting to see if it improves performance. One of those settings is slow with RReady.
QEMU seems to have hit a brick wall. It seems like the older legacy BIOS for QEMU can't be compiled anymore. The latest and greatest version now support EFI I think. I seem to have hit a brick wall there.
Reply 2973 of 3317, by sharangad
vQuake 2 upcoming fixes:
https://youtu.be/oZhjaSi-iGo
Once again thanks Raven-05.
I'm looking at the resolution problem and some issues with GPL as well. Those will have to come before the next release.
Does anyone know if there's a version of CWSDPMI that can use more than 64 MB of RAM? Dosbox-Rendition forces 512 MB of system RAM, but the vQuake only allocates 60 MB for some reason.
Reply 2974 of 3317, by sharangad
Does anyone know if the heap size can be increased in vquake?
I've seen the -heapsize command being bandied around, but it doesn't seem to work with the DOS version.
Reply 2975 of 3317, by sharangad
GPL appears to be working fine, so at some point next week I'll have to gear up for a release with the vQuake fixes, though they don't appear to be urgent.
Replays of Mexico City, Monza and Mosport are here:
https://youtu.be/VkwHoTWJcn0
At least one user on youtube reported issues with GPL on an RX6700 XT. Unfortunately getting hold of an AMD card around here is a bit difficult. Also I've noticed OpenGL driver quality varies between cards.
I just realised I'd never tested the X-Men expansion for vQuake and I just did. It appears to work quite well:
https://youtu.be/QXQjXYMHino
I really need to crack on with the CGL stuff as well. "Time is the fire in which we burn!"
Reply 2976 of 3317, by sharangad
One of the problems with the CGL stuff is that the disassembly reads in header data which points beyond the end of file.
For instance section#2 begins at offset 0x3007B from the start but the file is only 0x18447 bytes long.
File size is 99399 (00018447)
Section header block is 123 (0000007B)
Base ptr 0000007B, data offset 0000004C, data count 2, Seeking to 000000C7
File pos 199 (000000C7) Size of data sec #0 is 90016 (00015FA0), sub count 11, offset 0001007B, entry data 00002003
File pos 223 (000000DF) Size of data sec #1 is 38243 (00009563), sub count 10, offset 0003007B, entry data 00002005
Total size 128259 (0001F503)
Reply 2977 of 3317, by sharangad
if someone with a copy of "Grand Prix Legends" and an AMD Radeon RX 6700 XT could do some tests for me it would be extremely useful. I desperately need to run some tests. Apparently everything from the menus onwards are corrupted.
Reply 2978 of 3317, by sharangad
Some progress, maybe:
Name length 17,
Name length 19,
Texture index 20, reference 0 for idx 20, sub 0 is [OK]
Name size 160, base offset 0000007B, name sec off 0000004C, target offset 000000C7, current position 000000C8
Name length 0, ""
Name length 0,
Name length 237, ""
Name length 11,
Name length 116, "yle_
Name length 108, "SetDepthCueColor_"
Name length 99, "glLockBuffer_"
Name length 101, "tPalette_"
Name length 95,
Name length 16, "cglBoardPresent_"
Name length 16, "cglQueryFeature_"
"cglEventRegister_"
"cglEventDeregister "
Name length 18, "cglBoardConfigure_"
Name length 0,
Name length 2, "
Name length 0,
Name length 52, "$"
Name length 92, "1"
Name length 16, "k"
Name length 1, "l"
Name length 0,
Name length 103,
Name length 0, ""
ath
I haven't actually reached the bit where the function pointers are loaded, but far enough to misread the function names.
Reply 2979 of 3317, by Makus
sharangad wrote on 2025-07-13, 05:50:
Hi sharangad,
I found some resources on CWSDPMI memory allocation over 64MB:
- https://groups.google.com/g/comp.os.msdos.djg … sxHgsmQUJ?pli=1
- https://github.com/TritonDataCenter/sdcboot/b … mi/cwsparam.doc
- https://www.bttr-software.de/forum/board_entry.php?id=15829
