Reply 2980 of 3184, by terryfi
Synoptic wrote on 2022-06-20, 19:28:terryfi wrote on 2022-06-20, 18:21:I get the idea but the layer is a bit too thick worried me, if I add solder paste and heat, I am not sure if the 0805 will sink […]
Kahenraz wrote on 2022-06-20, 18:17:What's wrong with pre-tinning? This keeps the copper from oxidizing before it gets to you.
I get the idea but the layer is a bit too thick worried me, if I add solder paste and heat, I am not sure if the 0805 will sink and be flush with the board.
Maybe I should use less solder paste, maybe I am just paranoid because I never soldered on this much pre-tinned board before.
I am also worried the tinned layer will affect soldering with hot air, maybe part won't adhere as it might disturb surface tension of solder paste.Just add paste flux and heat up !
I will experiment to use flux to stick few and see if I can hot air them at once without using tweezers for each.
