Reply 30 of 37, by dvwjr
Here is another report on a VESA compliant video adapter which functions the same under DOS **and** WinXP for all the VESA mode applications that the VBE 3.0 compliant video supports. It is the on-board VGA/Graphics accelerator included on some models of the new Intel 82915G/GV/910 GL Express Chipset, also know as the Intel 900 Graphic Media Accelerator. The particular motherboard in question is the AOpen i915Gm-I populated with 512mb of PC3200 DDR RAM and an Intel 2.8gHz LGA 775 Pentium IV processor. It also had built-in Intel 10/100 Ethernet and built-in RealTek 7.1 HD sound. It is a microATX board with only four slots, two "legacy" 32-bit PCI slots, one PCI-e 1x slot, one PCI-e 16x (for video upgrades) slot. The on-board video used 8mb of the main system RAM for starters and up to 128mb of system RAM for 3D games if required. Not bad for $100 motherboard as an upgrade for a relatives PC...
The video quality in DOS/VESA fullscreen graphics mode is great, however with Windows text applications such as Web browsers the text on the analog VGA output is not as visibly sharp as Matrox video adapters. If the Matrox G450/550s are a "10" for Windows text readibility, then the Intel 900 Windows text readibility is around an "8.8" in my opinion. Very good, just not quick as defined and sharp as Matrox video adapters.
The Intel driver developers wrote the video driver properly, combined with the latest Intel video driver version release 6.14.10.3943 which includes the Video BIOS version 3329. They allowed the Intel VGA BIOS to 'touch' the proprietary SVGA extention registers to enable VESA support in the WinXP DOS emulation fullsceen mode, which many other video card companies neglect to do, leading to those video adapters not functioning in VESA modes under WinXP.
Here are the results from the VGATEST.EXE program which show that the Intel graphics driver developers allowed the Intel 900 proprietary SVGA registers to be modified under WinXP, because the BIOS supported VESA modes work. Would make an ideal DOS gaming platform under the WinXP DOS emulation, very good with VESA compliant DOS games. For Windows XP use, does excellent work with DVD viewing with its video acceleration (DVD viewing requires only 3-5% CPU resources), probably just fair (comparable to GeForce 4 MX440) for modern 3D Windows games, very good color correction (RGB gamma, brightness, contrast) for the Desktop and seperate color correction for the video overlay.
Results of VGATEST.EXE:
Intel 900
Graphic Media Accelerator DOS WinXP (SP2)
mode 0 OK 70Hz OK 70Hz
mode 1 OK 70Hz OK 70Hz
mode 2 OK 70Hz OK 70Hz
mode 2 scroll OK 70Hz OK 70Hz
mode 3 OK 70Hz OK 70Hz
mode 3 scroll OK 70Hz OK 70Hz
mode 3 extend OK 70Hz OK 70Hz
mode 7 OK 70Hz OK 70Hz
mode 7 scroll OK 70Hz OK 70Hz
320x200/4c (mode4) OK 70Hz OK 70Hz
320x200/4c (mode5) OK 70Hz OK 70Hz
640x200 B/W (mode6) OK 70Hz OK 70Hz
320x200 16c (mode D) OK 70Hz OK 70Hz
640x200/16c (mode E) OK 70Hz OK 70Hz
640x350 (mode F) OK 70Hz OK 70Hz
640x350/16c (mode 10) OK 70Hz OK 70Hz
640x200/2c (mode 11) OK 60Hz OK 60Hz
640x480/16c (mode12) OK 60Hz OK 60Hz
320x200/256c (mode 13) OK 70Hz OK 70Hz
VESA 100 640x400/256c OK 70Hz OK 70Hz
VESA 101 640x480/256c OK 60Hz OK 60Hz
VESA 103 800x600/256c OK 60Hz OK 60Hz
VESA 105 1024x768/256c OK 60Hz OK 60Hz
VESA 107 1280x1024/256c OK 60Hz OK 60Hz
VESA 111 640x480/64kc OK 60Hz OK 60Hz
VESA 114 800x600/64kc OK 60Hz OK 60Hz
VESA 117 1024x768/64kc OK 60Hz OK 60Hz
VESA 11A 1280x1024/64kc OK 60Hz OK 60Hz
VESA 112 640x480/16.8mc OK 60Hz * OK 60Hz *
VESA 115 800x600/16.8mc OK 60Hz * OK 60Hz *
VESA 118 1024x768/16.8mc OK 60Hz * OK 60Hz *
VESA 11B 1280x1024/16.8mc OK 60Hz * OK 60Hz *
(next modes failed)
* test picture was only in the left part of the screen
- refresh rates changes are possible in VESA mode under
WinXP with VBEhz.
dvwjr
edit: updated with SVGATEST.EXE
