Reply 300 of 396, by Baoran
DenizOezmen wrote on 2023-07-19, 20:18:
Baoran wrote on 2023-07-19, 17:55:
Do any of these bios files work with standard Asus Cuv4x that has the isa slot and no audio?
Probably not. If you're willing to test, I could try and prepare a port sometime in the next few days.
There is no need to rush but one of my main retro PCs has that motherboard and I would really like more options.
Reply 301 of 396, by riplin
I installed this bios on my P3B-F and it’s working like a charm!
I do have one question. I’ve got a Promise SuperTrak SX6000 installed and it has a rather beefy rom sitting at C0000-D0000. The bios doesn’t cover the first part of the C0000 range so I can’t shadow this rom. Are there any possibilities to add extra shadow regions?
Reply 302 of 396, by DenizOezmen
Zerthimon wrote on 2023-07-19, 20:29:
I would like to know if it's gonna work.
Baoran wrote on 2023-07-19, 21:10:
Here's a test build anyway. 😉
riplin wrote on 2023-07-19, 21:19:
The BIOS does handle shadowing of the C0000-C7FFF range, which it specifically uses for the video ROM, so this "hides" behind the "Video ROM BIOS Shadow" option.
However, ROMs of PCI cards are always shadowed into RAM anyway, and the (PnP) BIOS determines the memory range by itself. So you should need the shadowing options only for ISA cards.
[Edit: Moved download. See first post.]
Reply 303 of 396, by Zerthimon
DenizOezmen wrote on 2023-07-20, 16:18:
Here's a test build anyway. ;
Thanks, Deniz!
That was so fast. Nice one!
However, i'm not able to test your BIOS as I don't have this motherboard yet. I do have the DLS version though, but I thought I'd wait to see how the things go with the cuv4x BIOS first.
Reply 304 of 396, by Baoran
Thank you. You managed to do it really fast.
Reply 305 of 396, by Boohyaka
Hey Deniz! Just wanted to let you know that I've restored my P3B-F and programmed the latest BIOS, the -5V rail monitoring error is gone as expected - can choose between Ignore and N/A in HW monitoring, guess that's the desired result 😀 big thanks as usual!
Reply 306 of 396, by DenizOezmen
Thanks for all the feedback! Glad to read the mods are helpful to you.
Zerthimon wrote on 2023-07-20, 17:07:
No problem. In case you want to try it sometime, here's a test build for the DLS.
Reply 307 of 396, by Zerthimon
DenizOezmen wrote on 2023-07-22, 13:42:
Thanks, Deniz!
Will test it next week and report back.
Reply 308 of 396, by Baoran
CUV4X version seems to be working fine. I have a coppermine cpu running at 1.5V and hardware monitor shows the set voltage correctly too.
Reply 309 of 396, by riplin
Sorry for the n00b question. I was running a memtest and suddenly the program started stuttering and I was hearing high pitched beeping from the speaker and the power led was flashing. This lasted less than a minute and then it stopped. The memtest itself was still running fine, no errors detected, so I don't think it came from there? I rebooted into the BIOS but I didn't see any messages (or perhaps I didn't look in the right place). I restarted the memtest again and it started beeping again.
The CPU heatsink didn't really feel very hot and the fan was spinning just fine. The video card on the other hand was quite hot. No idea if it's normal for the model I have. An NVidia Geforce4 Ti 4600 128MB.
System is a P3B-F with a 1Ghz Coppermine SL52R @ 133Mhz FSB, voltage is at 1.75V.
This is with BIOS patch 20230709.
Edit, I ran it again and immediately rebooted into the BIOS to see the HW monitor values when it started beeping:
About those voltages, I'm using a brand new EVGA 100-W1-0500-KR 500 W1, 80+ White 500W, 3 Year Warranty, Power Supply 100-W1-0500-KR
Reply 310 of 396, by DenizOezmen
Baoran wrote on 2023-07-22, 19:05:
Interesting, thanks! The CUV4X BIOS is based on a relatively new build. Maybe ASUS had moved initialization of VCore to an earlier spot by then.
riplin wrote on 2023-07-25, 02:15:
I'm not sure what exactly might cause the beeping and stuttering, but if you want to make sure it's not the mod's fault, you could try again using the stock BIOS. It should work in your configuration (except for the non-critical hardware monitor error due to the missing -5 V rail).
A note on the voltages: Strictly speaking, the +5 V rail is out of spec according to the ATX standard (5 V +/- 5%, so no less than 4.75 V).
Usage of the rails (and thus the design of power supplies) has changed considerably since the days of early ATX systems: Back then, PCs got most of their power from the +3.3 V and +5 V rails, while today's PCs depend heavily on the +12 V rail(s). This means two things:
  • While your power supply can nominally deliver 500 W, a Pentium III system cannot utilize most of this power. Instead, it draws almost excusively from the +3.3 V and +5 V rails, which are rated with a combined output of "only" 120 W. (The +12 V power basically only goes to the system's drives.)
  • The PSU is loaded "the wrong way" (cross load): Since today's PSUs expect to be primarily loaded on the +12 V rails, some of them can develop problems if that is not the case.
I'm not saying that this is necessarily the problem here (and there are debates on how much of an issue this actually is unless you want to run a power-hungry Athlon system). Still, it is something to be aware of when choosing a PSU for a retro system. Should you have a different PSU at hand, you might want to try that one.
Reply 311 of 396, by riplin
DenizOezmen wrote on 2023-07-25, 16:11:
I'm not sure what exactly might cause the beeping and stuttering, but if you want to make sure it's not the mod's fault, you cou […]
I just upgraded the system to a Tualatin 1.4GHz CPU so I would have to still run a modified BIOS.
As for the power, I do load the 12V with 3 hard drives. I'll check to see if the 5V rail is in spec on initial boot. Perhaps the drop below 4.75V is what's triggering the beeping? Not sure what to do about that other than swapping out the power supply. Anyone have a suggestion for a good modern replacement?
I've also googled the issue and one thing that came up was people mentioning that P3B's have issues with certain power rails to the processor having spikes. They soldered on all kinds of capacitors on their slotkets. I really hope I won't have to go that route.
I should probably also mention that the cpu temperature bounces around between 52c and 60c while just sitting in hardware monitor. I’m not sure if I 100% trust the numbers it’s reporting there.
Edit: I disabled the CPU temp monitor and now the beeps seem to be gone. It's been running memtest86 for almost half an hour now and it would usually start beeping around 10 minutes in.
Edit: I ran CPUBurn for an hour and all is fine.
Reply 312 of 396, by DenizOezmen
riplin wrote on 2023-07-25, 16:58:
Ah, that makes sense. I seem to remember seeing a board with strange CPU temp fluctuations. No idea what causes this, though.
Reply 313 of 396, by mockingbird
@DenizOezmen - I would like to request from you please your excellent treatment for the Asus P2B-S as well (which POSTs with the Ezra-T, unlike the P3B-F). Please see attached BIOS (downloaded straight from Asus). Thank you very much again for all your great work!
    1014s003.zip
    196.11 KiB
    40 downloads
(Decommissioned:)
Reply 314 of 396, by DenizOezmen
mockingbird wrote on 2023-08-03, 06:01:
Should be possible. Here's a quick test build.
[Edit: Removed obsolete attachment.]
Reply 316 of 396, by DenizOezmen
mockingbird wrote on 2023-08-03, 17:41:
Thank you! I will test it and report back.
Sorry, I'll have to push a correction. I got some offsets wrong in the last build ...
[Edit: Moved attachment.]
Reply 317 of 396, by nizce
Hi!
Just found out about this modified bios, great @DenizOezmen !! 😀
Will try on my p3b-f.
I also have an another 440BX motherboard called P2BXA made by a company called DCS.
Would it be possible to make a compatible bios for that motherboard as well in the future?
Reply 318 of 396, by DenizOezmen
nizce wrote on 2023-08-05, 20:27:
Thanks!
A mod for this board would need fresh reverse engineering work and possibly a new code base. As I don't own related hardware, I'm probably not going to port all kinds of changes blindly. If there's something specific that doesn't work for you, I can try and take a look at that, though.
Reply 319 of 396, by mockingbird
DenizOezmen wrote on 2023-08-03, 21:19:
Thanks! Confirmed working great as expected... Best wishes.
(Decommissioned:)
