Reply 30460 of 58013, by jaZz_KCS
- Oldbie
wrote:While I have Serdaco X3MB which should be Sound Canvas replica I felt I need little-bit more bling and alternate GM sound. […]
So I bought this one off the ebay.
"Thanks" Hermes/DPD for nice delivery across Europe. 😒 I managed to straighten them up. Then checked for short with multimeter and plugged into wall (yeah slightly suicidal I know).
It worked, but I measured over 17V on output plug. Well it should be 12V. No way I'm going to put that into my precious vintage midi module.
So I found modern replacement power brick with similar output and it worked. So I'm happy.To my amazement Monkey Island in Roland mode and MU50 in "C/M" not "XD" mode sounded quite OK. I need to test little more with various games. This C/M mode might work like limited MT-32 replacement.
17V seems still alright keeping in mind that the voltage will drop severely when on load.
9V power supplies also show well beyond 12V when not under load. This is pretty normal. Albeit arguably, 17V is already a tad high. 15V would be totally fine as it will surely drop down to the vicinity of 12V when under load.
Regarding Hermes. Domestically and internationally I had very good experience with Hermes.
