![$_12.JPG](http://i.ebayimg.com/t/Memory-48-x-72Pin-SIMM-EDO-Memory-Stick-Module-Various-Sizes-1MB-8MB-/00/s/MTA1OFgxNjAw/z/osYAAOxydB1SnQt-/$_12.JPG)
Lot of 48 72pin simm sticks
Multi i/o with bios looks great and for less
![DSC_7912_multi_io.JPG](http://www.digispares.eu/ebay/DSC_7912_multi_io.JPG)
![DSC_0445_linkpro_hub.jpg](http://www.digispares.eu/ebay/DSC_0445_linkpro_hub.jpg)
Link pro combo HUB for only 1 euro,10Base-T / 10Base2 Hub (TP und BNC)
![DSC_0444_edimax_hub.jpg](http://www.digispares.eu/ebay/DSC_0444_edimax_hub.jpg)
Edimax 9-Port 10Base-T / 10Base2 Hub (TP und BNC)
(why no switch, is because there are no switch available with BNC i know off, and for only 1 euro its not a problem either, i want to link all of my retro computers together, so easier to share and replace the files.)
![$_12.JPG](http://i.ebayimg.com/t/80486-VLB-Mainboard-AMD-486-DX4-100-MHz-32-MB-RAM-TOP-/00/s/ODA1WDEwMjQ=/z/51cAAOxygPtSxbdO/$_12.JPG)
second chicony CH-471B motherboard, i needed this one to repair my other one i have laying here.. Need to measure the resistors on the VRM part, and want to try the new bios out on my older board.. So i finally can finish my older board to full working one with other voltage processors. The lot is with 32Mn FPM memory and AMD 486 DX4 100 8VSB.. ive got already some here.
ABIT AH-4T 486 socket 3 motherboard..
I think that would be the last board for now. Then i have about 6 -7 486 boards. one came with the cases i bought that an socket PGA 1.. The rest is all socket 3 boards. I have got now 4 boards with voltage regulators..
That would be:
Freetech 486F38 cpu auto voltage with Rev G bios (support till AMD 5x86 P75, and no y2K anymore)
QDI V4P895P3 / SMT V4.0 (wrote a new bios from the SMT 5.0 board)(now support till AMD 5x86 P75)(the older bios didnt work on the board, board didnt go on, so was dead on the bios rom)
QDI V4P895P3 / SMT V5.0 (support till AMD 5x86 P75)
ADI TK8498F/GP 4N D24 (only 5V processors for now, tested with an voltage interposer board till AMD 486 DX4 - 100Mhz) Iam working on it to support more voltages.
Chicony CH-471B REV 1.0 (missing the VR part, hope i can fix it with the knowledge of the other board i bought. Also hope i can use the bios)
Chicony CH-471B REV 2.0 (the board that is listed on the upper side) Does have the VRM part and maybe a later bios version the seller says it could do till 8.4GB drives, so i guess its the right bios that would solve any Y2K bugs, and i guess it would have better cpu code support (i hope it will do AMD 5x86 P75 ones too)
Chaintech 486 SLD motherboard - Now it would do only 5volt processors, bios is junk as well. So need to fix this board too.
Chaintech 486 SLD /SLP (have VR onboard and supports 5,4, 3.3 volt processors) Got the same problem that the bios is junk
Chaintech 486 SLE (Without an VR onboard, have the same circuit as 486SLD, board not tested yet. I hope i can use this bios for the other two chaintech boards and get rid off 2YK bug..
Abit 486 AH-4T VLB socket 3 motherboard Doesnt have the VR part too, trying to get it fixed on the VR part.
Thats all i have got on 486.. Time flies..
