Reply 3060 of 3230, by sharangad
RaVeN-05 wrote on 2025-07-31, 06:30:
almost perfectly Rabel Moon rendered.
Some very little noticeable minor graphical glitches left.
Thanks @Raven-05, will fix them.
https://patreon.com/Rready
Reply 3061 of 3230, by sharangad
Bugs 003 happens on original hardware and it looks to be an z-buffering bug or lack of. I would post a video, but my capture dongle doesn't go any lower than 640x480 .
Reply 3062 of 3230, by sharangad
And the final one. Sorry about these being JPEGs. I attached them to the post instead of linking against my server.
The other two will be fixed.
Reply 3063 of 3230, by sharangad
Rebel Moon Fixes (hopefully final):
https://nirvtek.com/downloads/RReady.Alpha.20 … 01.RebelMoon.7z
MD5: 2632214aa3080804262a57d459aa4997
- This *should* correct all outstanding Rebel Moon chroma keying bugs and perhaps not introduce new ones.
- There is a problem with the keyboard input sometimes not responding in the dosbox window after existing a Speedy3D game. Pressing [ALT] fixes this. This will be fixed .
[EDIT]Attaching PNG images to the forums produces cel-shaded low bitrate attachments. So here are links instead. So here are JPGs/[/EDIT]
[EDIT]At some point I should put up a video on how this was fixed[/EDIT]
Reply 3066 of 3230, by sharangad
A brief overview of how the Rebel Moon bugs were fixed using screen space derivatives is available here:
https://www.patreon.com/posts/overview-of-moo … ntent=join_link
and
https://youtu.be/vH-zlu9VKT0
Reply 3067 of 3230, by sharangad
ICR2: I've increased the base memory used by the game to its limit of 64 MB. The texture heap is a separate 256 MB. I think there's still some sort of internal partitioning going on, which stops the extra memory from being used.
By restricting Dosbox's RAM to 16 MB I got this:
V:\CR>cart
DOS/32A -- Protected Mode Run-time Version 7.35
Copyright (C) Supernar Systems, Ltd. 1996-2005
Sierra On-Line, Inc.
Version 1.0.2-RN1 Build #61
DMA Memory fragmentation:
Pointer buf :
Command buf :
Digital Sound
Port 220 IRQ 7 DMA 1
Conf irmed with SB16 8 ST
Memory Check: 584000 LO 13602800 HI 14186800 ALL
Insufficient memory. Free up 69013168 bytes, and try again
V:\CR>mem
632 Kb free conventional memory
63 Kb free upper memory in 1 blocks (largest UMB 63 Kb)
14912 Kb free extended memory
14912 Kb free expanded memory
This is with a 256 MB texture heap. It's complaining about the *other* memory (other than the texture heap).
69013168 = 69 MB. This version of the game needs 256 MB alone for the heap, so this has to mean it's complaining about everything else. Usually the entire game needs just 16 MB, with 6 MB for the texture heap and 10 MB for the rest. I *think* if I can unpartition the thing to use mroe RAM, textures would just work.
https://nirvtek.com/downloads/ICR2.64MB.OtherMemory.001.7z
MD5: 4ed3bc2eb1973c8809031bf9c3e7aae8
(This link is fairly useless, since the game behaves exactly the same, but I need it preserved in case of catastrophic hard drive and backup failures).
Reply 3071 of 3230, by sharangad
RaVeN-05 wrote on 2025-08-02, 16:15:
tested Rebel Moon, its perfect now! =)
Thanks a lot for all the testing!
I have another build:
https://nirvtek.com/downloads/RReady.Alpha.20250802.004.7z
MD5: c32b89f0ac8c80bad0708b90b031ef6b
which should allow vquake to run on your laptop (dual core).
You'll need to set
threadsafe=false
highperformance=true
picdma=true
override2core=false
ICR2 should be full speed again. I don't know if the games will be stable without major lockups. I've been spending some each day trying to reduce the cpu load of the whole process. Custom carsets in ICR2 probably won't be possible. This will force a bunch of settings if you the CPU has fewer than 3 cores. Enforced thread prioritization has been disabled. So the possibility of hiccups and slowdowns even on quad or better systems is higher, even when dual core settings aren't enforced.
[EDIT] On some systems (Haswell Pentium 3 GHz Intel HD graphics) threadsafe=true, picdma=false, highperformance=-true and override2core=true works really well for ICR2, but not vquake. On my Ryzen 2700X in dual core mode the Haswell settings are terrible. It works much better with the first bunch of settings under the download link.
Reply 3072 of 3230, by sharangad
This is looking like the next release candidate:
- vQuake cvars d_dither and d_bilerp should work correctly
- Rebel Moon all chroma keying bugs should be fixed.
- ICR2 [ALT+B] (autobrake) should function correctly.
- Formula 1 RRedline performance boost (including for everything using paletted textures).
- Improved dual core performance in a default config. (Needs more testing). The minimum required GPU (Intel HD4000) should perform better on the minimum CPU dual core 3 GHz (Haswell).
I think it's better to do incremental updates instead of massive ones with lots of fixes. It's a lot easier to test and isolate problems.
[EDIT]
Or with the same optimization extended to quad cores and beyond:
https://nirvtek.com/downloads/RReady.Alpha.20250803.001.7z
MD5: 031f0bd95305993dc4cd34cd97218f09
I really need to rebuild my Sandy Bridge HD2000 based machine. Motherboards are available, but i don't know whether the CPU still works. The i7 2600 still sells for quite a bit.
[/EDIT]
[EDIT2]
Detroit Belle Isle (2004-1995, 2/4 of these are regurgitated), Detroit Downtown HQ (new) and Houston:
https://youtu.be/yOmgm3wNZXk
[/EDIT2]
Reply 3073 of 3230, by sharangad
My day job is figuring out ICR2, but I spend an hour each night working on CGL:
This appears to be the entry point for cglInitScreen in the source:
* FUNCTION
undefined FUN_000160f5 (undefined param_1 , undefined pa
undefined AL:1 <RETURN>
undefined AL:1 param_1
undefined DL:1 param_2
undefined CL:1 param_3
undefined4 Stack[0x4]:4 param_4 XREF[1]: 000160f9 (R)
FUN_000160f5
000160f5 53 PUSH EBX
000160f6 56 PUSH ESI
000160f7 57 PUSH EDI
000160f8 55 PUSH EBP
000160f9 8b 74 24 MOV ESI ,dword ptr [ESP + param_4 ]
14
000160fd 31 db XOR EBX ,EBX
000160ff 66 89 f3 MOV BX ,SI
00016102 89 d8 MOV param_1 ,EBX
00016104 e8 6c fb CALL FUN_00015c75 undefined FUN_00015c75()
ff ff
00016109 66 85 c0 TEST param_1 ,param_1
0001610c 0f 85 bd JNZ LAB_000161cf
00 00 00
00016112 e8 7e 1e CALL FUN_00017f95 undefined FUN_00017f95()
00 00
00016117 a3 44 5f MOV [DAT_00025f44 ],param_1
02 00
0001611c 85 c0 TEST param_1 ,param_1
0001611e 75 0a JNZ LAB_0001612a
00016120 b8 03 80 MOV param_1 => DAT_00008003 ,DAT_00008003 = 14h
00 00
00016125 5d POP EBP
00016126 5f POP EDI
00016127 5e POP ESI
00016128 5b POP EBX
00016129 c3 RET
This is my hacked version which output a constant to a port. It doesn't work. It return 0x8003 and skips the RETurn instruction completely. Assembler gurus, what gives? Is it entering the function with an offset and not at the entry point?
* FUNCTION
FUN_000160f5
000160f5 50 PUSH param_1
000160f6 b8 12 16 MOV param_1 ,0x1612
00 00
000160fb 67 52 PUSH param_2
000160fd ba 00 c8 MOV param_2 ,0xc800
00 00
00016102 ef OUT param_2 ,param_1
00016103 5a POP param_2
00016104 58 POP param_1
00016105 c3 RET
00016106 fb ?? FBh
00016107 ff ?? FFh
00016108 ff ?? FFh
00 00 00
00 00
02 00
00016120 b8 03 80 MOV param_1 => DAT_00008003 ,0x8003 = 14h
00 00
00016125 5d POP EBP
00016126 5f POP EDI
00016127 5e POP ESI
00016128 5b POP EBX
00016129 c3 RET
With Furan's 3DBInfo tool:
V:\DOS\3DBINFO>dos4gw 3dbinfo
DOS/4GW Protected Mode Run-time Version 1.97
Copyright (c) Rational Systems, Inc. 1990-1994
3D Blaster Info 0.1 by Ian Hanschen
Attempting driver load (fixed)
cg 1QueryScreen
Error: -32765 (FFFF8003)
[EDIT] Oh, I see the problem. It's not returning 0x8003. It's returning DAT_8003.
Reply 3074 of 3230, by RaVeN-05
Tested Indy Car Racing II.
The ALT+W (Change weather) seems works slowly not all the times, like ALT+B before fix. Feels need to be fixed.
The only font buggy when activating ALT+R (show FPS) and ALT+X (test mode) look screenshot
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 3076 of 3230, by sharangad
RaVeN-05 wrote on 2025-08-06, 12:13:
This is the case even on original hardware. The readme file actually mentions that [ALT+W] might respond slowly.
This is a bug and will be fixed. It's a bit of a low priority bug. The text and black background is missing in some frames.
Also could you test ICR2 and vQuake on your dual core laptop? vquake should actually run now. ICR2 should be stable as well.
Reply 3077 of 3230, by sharangad
The latest Alpha:
https://nirvtek.com/downloads/RReady.Alpha.20 … R2Chroma.001.7z
MD5: 36de8eb91b96452d7379c36be0f69a6c
- This release should allow software rendered DOS ICR2 to run in dosboxes-rendition and staging-rendition.
- Keyboard performance tweaks
- preliminary support for polygon texture transparency. To enable it for supported track (currently there is none) add the following to rendition.cfg:
noicr2transparency=0
Reply 3078 of 3230, by sharangad
The byte ordering is wrong here. I think this is a direct mem write to the framebuffer. Also I think it doesn't target the third framebuffer. This game and the Nascar 99 use forced triple buffer which is simulated by RReady since it doesn't directly translate to OpenGL's triple buffering. There're reads from the third buffer in sequence. Will look at it later tonight.
