BitWrangler wrote on Today, 04:49:
Ozzuneoj wrote on Yesterday, 18:38:
And yes, I'm aware that it incorrectly says that it is S-video. They seem to be producing cables without even knowing what they are used for.
I think they were maybe used in some early S-video applications, like for transfer off camcorders that were as big as a stinger launcher or had a separate minitower sized handbag for the deck.
All I could find are cables that break out from that to a set of component cables. I'm thinking that's probably what they were most commonly used for.
In other news, the floppy drive on the 1040STf was not happy, and some quick googling told me that these are known to have bad caps. Sure enough, it has some of those evil way-too-early-for-their-own-good surface mount aluminum electrolytic caps. Not the ones used in the 90s, but the ones that usually have a little yellow label wrapped around them. Anyway, everything on the PCB had a bit of a corroded look to it, so I figured they were toast.
It ended up being a surprisingly time consuming repair (because the motor absorbs SO MUCH heat from the board and the solder had so much corrosion on it that nothing would melt), but I eventually got all of the electrolytics replaced. I did basically the same thing as this post:
https://www.exxosforum.co.uk/forum/viewtopic.php?t=3147
Now, I'm happy to say that it works perfectly! The system boots up in seconds thanks to the OS being on ROM, and these STs are so stinking awesome that they read standard 720K IBM formatted floppies AND text files with nothing but the ROM loaded. I just popped an old 720K floppy into a Dell USB drive connected to my Windows 10 system, put some text files on it, put it into the ST, double "clicked" (I had to use alt+arrow keys and alt+insert) the floppy drive and there everything was...
The attachment 20260109_021028.jpg is no longer available
The attachment 20260109_021008.jpg is no longer available
I think I'm going to like tinkering with this machine.
Also, I had a friend 3D print a replacement key stem for one that was broken. I had to sand that down a bit, but it also works perfectly. It feels good to give a machine like this a new lease on life. I will post more pictures (and maybe a thread) once I am done reassembling it. After working on the floppy drive waaay too late and then cleaning up my work desk, I'm done for the day. 😌
EDIT: Forgot to mention, the monochrome VGA adapter cable it came with allows it to work on any of my CRTs as well as my Dell Ultrasharp 2001FP, as pictured. It is a little wobbly and has some lines on the LCD but looks perfect on a CRT.
... also, it turns out this 2001FP I was given a few years back is one of the unicorns that was made before they broke 15Khz horizontal refresh support... so I can either get a different adapter or rewire this one to use the ST's color video modes and it should work. 🙂
