Reply 3080 of 58600, by PeterLI
Your Digital Venturis is very nice. It looks like a Pentium 75 version I have. 😊
Got a MPU-IPC-T & MT-32 bundle in today. I still need to test it: MPU-IPC-T works.
Reply 3082 of 58600, by PeterLI
Reply 3084 of 58600, by carlostex
How is your head after your wife hit you with a frying pan?
Reply 3085 of 58600, by PeterLI
Reply 3086 of 58600, by tincup
Mau1wurf1977 wrote:
One doesn't seem to work. Computer just beeps. Will take a closer look at it later 😀
If it's the top card, hold onto those un-soldered ram clips. They'll come in handy in a future video card ram upgrade..
Reply 3087 of 58600, by easy_john
Roland SCC-1 from PeterLI
ISA_Roland_SCC-1_f.JPGlink
Pentium2 450/256mb/4gb/ati rage 128+voodoo2/SB awe32 8mb+db50xg/GUS PnP 8mb/TB Tropez 2mb
486 DX2-66/32mb/8gb/tseng4000 2mb/SB 16+WB/GUS 1mb/LAPC-I
286 12mhz/4mb/512mb/Vga 1mb/SB 2.0+Covox
PegasosII G4 / Amiga 4000 / Amiga1200 / Amiga 600
Reply 3088 of 58600, by Robin4
My second overdrive 100 mhz processor (price wasnt very bad, with free shipping.
What iam going to do with these parts? Ill keep them in own stock.. So i can decide, which processor, memory, board i can take for use.
Reply 3089 of 58600, by PeterLI
Very nice John! Enjoy! 😀
Reply 3090 of 58600, by sliderider
Robin4 wrote:
http://i.ebayimg.com/00/s/NDgwWDY0MA==/z/OfIAAOxyOlhS1rdA/$_3.JPG […]
I don't see the point of buying 486 Overdrives.They usually sell for more because of the word "overdrive" on then than the "normal" DX4 chips and an AMD DX4-120 or 5x86-133 can be had for less and make a faster system. The only Overdrives I bother with are POD 83 (if they're cheap enough), Pentium MMX Overdrive or Pentium II Overdrive.
Reply 3091 of 58600, by Mau1wurf1977
That overdrive works on more 486 board than the AMD chips. The Intel is also faster clock for clock compared the 5x86 P75. I tested this myself.
For example on my Acer it gets detected properly, whereas the AMD shows up as DX2-80.
My YouTube channel
Reply 3092 of 58600, by DonutKing
The DX4 Overdrives have a voltage regulator on board so they will happily run with 5V. The normal DX4's are designed for 3.3V so you need a motherboard that supports it.
Supposedly there are AMD DX4's that are 3.3V/5V tolerant but I haven't been able to confirm this.
The 5x86's are also designed for 3.3V or 3.45V. You can get them with a voltage regulator onboard (eg Kingston Turbochip) so they will run at 5V, but these aren't quite so common.
In my own testing I found the Pentium Overdrive for socket 3 to be somewhat finicky in certain situations, and an Intel DX4-100 would generally beat it for DOS games at stock speeds. The POD83 was only better if you were using software/games optimized for Pentium or that used floating point (eg Quake), in which case why not just get a socket 5/7 Pentium, they seem much more common and cheaper than 486 class hardware.
Reply 3093 of 58600, by vetz
Could you please provide these benchmarks to Phil's thread/document? I'm the only one who have benchmarked my POD83 and that system is currently beating all the DX4 and AMD X5-P75 133mhz benchs at stock speeds (and overclocked).
Reply 3094 of 58600, by DonutKing
I don't have that system any more.
Reply 3095 of 58600, by Mau1wurf1977
Yea it's the top one.
Pulled the memory off the card and now the machine posts. But the image is grey-scale. There is a jumper that hasn't been set, might play around with it...
My YouTube channel
Reply 3096 of 58600, by bristlehog
MediaVision Pro Audio Spectrum:
MediaVision Pro Audio Studio 16 LMSI:
MediaVision Pro Audio Studio XL:
Here you can get fantastic wallpapers created by a friend of mine: patreon.com/Unpocodrillo
Reply 3097 of 58600, by Skyscraper
That looks like the photos my grandmother takes.
She usually only gets the back-end of animals and such in the image, the rest is cut off.
EDIT
Tham! You fixed it fast!
/EDIT
Reply 3098 of 58600, by PeterLI
Reply 3099 of 58600, by Artex
Agreed! That OG 8-bit PAS must not have been cheap. 😀
