Reply 31240 of 53045, by Turbo ->
wiretap wrote:
I'm guessing it powered an industrial ISA backplane -- especially due to the short power switch cable. You can certainly still use it if it is functional. You can add some of your own cables that you need (molex, floppy) by soldering directly to the board, or making an in-line breakout cable.
Well, it powers on, so I asumme it works. I also noticed short power switch cable when I held it in my hands. Thanks for the tip.
Reply 31241 of 53045, by Vincebus
if you have enough amps you could make an adapter from a dead mobo AT connector... make sure you are using proper gauge.
lo-fi fingers...
Reply 31242 of 53045, by Merovign
Turbo -> wrote:
Bought this AT Power supply yesterday for 5 EUR. When I looked at it more closely, I realised that it only has connections for the motherboard. No molex or floppy connections. What kind of power supply is this and what computers (motherboards) it is ment for? Is it possible to use it in an "regular" computer?
Assuming it's in good shape, using a donor set of cables from a dead PSU and a multimeter and soldering iron, you could map out the outputs and make a breakout cable. To be really slick you'd have to find out if someone like Mouser electronics has the other end connector for that big proprietary connector and use it to break out the molex, floppy and AT connections.
Kind of like an ATX-AT adapter.
*Too* *many* *things*!
Reply 31243 of 53045, by ShovelKnight
Made a lowball offer for a VIA Epia 800 (the original Epia with SB Pro compatible sound) which was accepted by the seller. Looking forward to seeing how this thing compares to AMD K6-2+/III+ In terms of performance and flexibility for old games.
Reply 31244 of 53045, by dionb
gca wrote:
I think you mean 16KB rather than 16MB unless I way underestimated what an 8-bit is capable of.
Oops, was tired+drunk yesterday 😵
That definitely was 16kB, not MB. There might be 8b systems out there that somehow manage 16MB, but the ZX81's definitely not one of them.
Reply 31245 of 53045, by Bancho
Finally managed to pick up a ARK based GFX card for a reasonable price.
This one is a Hercules Stingray 64 With the ARK200PV chip. Thinking of putting this into my P166 with Voodoo machine.
Reply 31249 of 53045, by Intel486dx33
Arrived this week.
1) Micro-Young VLB 486 motherboard ( Made in USA )
2) Mylex VLB 486 motherboard ( made in USA )
3) 486 CPU fans.
    658.44 KiB
    203.3 KiB
    319.13 KiB
Reply 31251 of 53045, by arncht
ShovelKnight wrote:
What's the difference between ARK2000PV and ARK2000MT?
like the trio64 and the trio64v+. accelerated video playing.
Overdoze of the demoscene
Reply 31252 of 53045, by Predator99
Predator99 wrote:
imi....where do you have been? :lol: […]
imi....where do you have been? 🤣
RAM-day today. Think 50€ is quite OK for this. I see many 30-PIN modules which are not easy to get for cheap...
sellers pic:
The attachment s-l1600 (1).jpg is no longer available
Arrived...all looking very good. Excellent deal 😎 Enough until end of time? 🤣
    1.73 MiB
Reply 31253 of 53045, by HanJammer
sellers pic:
These DIY SIPPs though ;d
I have similar bunch of modules... I just lack the time to test them...
Reply 31254 of 53045, by imi
sweet, I think I have enough ram to stock any system I have, though I only have very few 60ns sticks.
Reply 31255 of 53045, by RetroPC_King
Received today a Western Digital WD Caviar SE WD1600JD-22HBC0 160GB Serial ATA HDD. It is in a good shape.
    428.26 KiB
Reply 31256 of 53045, by MMaximus
sellers pic:
Nice! Do you have any SIPP in the lot?
Hard Disk Sounds
Reply 31258 of 53045, by Xicor
Have been in a busy frenzy @ the last couple of weeks, managed to rescue and buy a mixed "assortment" of hardware.
"Donated" (one can say that a couple of cups of Glenrothes where involved) by a friend, a cool keyboard from Cherry, and true cherry on top is it has a AT/XT selector 😎 . It had a ruff time, and was horribly dirty.
623.56 KiB
The switch's are "hybrid" rubber dome, but they to feel nice I think. Still dirty, but way better.....
578.51 KiB
After a full disassembly and thorough cleaning, keycap by keycap it turn out a nice keyboard to have.
584.39 KiB
Also found 2 bundles of assorted hardware on local used sale sites, and some goodies where barley visible.
First bundle (20€):
1004.77 KiB
933.15 KiB
Jumped to this lot mainly because I had the need for that 8bit OTIVGA. The AGP card was a nice surprise, as it is an FX5900XT.
The second lot has a tad more expensive (50€), but the AWE32 alone would justify :
https://photos.app.goo.gl/hxeNsFLZjq9BzeJA6
The P4 mobo seems to have a problem, and the floppy drives are still to be tested, but everything else works fine.
Reply 31259 of 53045, by liqmat
623.56 KiB
Good grief man. That so reminds me of a Coco 3 cleanup job I did awhile back. I am curious where that keyboard was found/stored? I found that Coco 3 in a dirty, humid Florida garage at a yard sale and it had been sitting there for almost 30 years. After the cleanup, fired right up and worked flawlessly.
1.85 MiB
