Reply 31820 of 53137, by Horun
LewisRaz wrote on 2020-01-04, 13:29:
Picked up the motherboard today. £12 win on ebay. Much better condition than expected but absolutely caked in grot, sticks and e […]
Picked up the motherboard today. £12 win on ebay. Much better condition than expected but absolutely caked in grot, sticks and even bird poop..
Everything looks like it will clean up nicely tho!
I did rip off the heatsink to see what I got and it appears to be a 750mhz pentium 3 (thats what the jumpers are set for)
The only immidiate concern is a scratch underneath has taken the protective coating from a few traces but the traces themselves do not appear to be broken.
Any advice on cleaning it up?
Nice Gigabyte board ! Yes use lots of Q-tips, paper towel, ISO 99% and elbow grease 😁
Reply 31821 of 53137, by Horun
PC Hoarder Patrol wrote on 2020-01-05, 03:01:
Seems Harris / Leitch used this particular board in quite a few different pieces of kit - a pic from a current listing
Thanks, I'm kinda new to this class of board and have been reading up on the different mounting & case options you mention.
Wow really nice ! Do you have any specs on it ?
Reply 31822 of 53137, by FluffyBunnyFeet
i was at a local e-waste when this was dropped off so i had to buy it...
ibm model f at keyboard...
it's in excellent condition. both flip out feet are still intact along with the rubber feet on the bottom plate.
i hurry home, plug it into a 486, power it up, the three led's on the keyboard flash and then
error.jpg 🤣
oh well, i'll pop it open sometime this week and see what's up. hope it's nothing major
Reply 31823 of 53137, by PC Hoarder Patrol
Horun wrote on 2020-01-05, 03:56:
There's a Wayback spec link and flyer for the board here Re: Bought these (retro) hardware today
Reply 31824 of 53137, by luckybob
@FluffyBunnyFeet
The ibm model F is designed for XT class machines only. It won't work in anything but, without a converter.
Reply 31825 of 53137, by xjas
FluffyBunnyFeet wrote on 2020-01-05, 04:39:
i was at a local e-waste when this was dropped off so i had to buy it... ibm model f at keyboard... [...] i hurry home, plug it […]
XT- and AT-type keyboards used different signalling and aren't compatible. Your 486 is expecting an AT keyboard & can't use this one natively. There's a good chance it works fine, you just need an older PC to use it on.
IIRC you can get a signal converter if you want to use this on a machine that takes AT-keyboards.
EDIT: THIS WAS WRONG. See Dionb's correction below. It is an AT-signalling keyboard after all. Didn't realize IBM made AT keyboards with this layout.
Reply 31826 of 53137, by appiah4
wirerogue wrote on 2020-01-04, 03:06:
nos inwin a500 case. a nice start to my next build.
You lucky bastard 😁 Best case ever.
Reply 31827 of 53137, by derSammler
Just won a lot of ISA cards (>30) for almost exactly 1€/card. I don't care for most of the cards, but there are two very interesting sound cards included. 😀 Also a couple of 3Com ethernet cards, which are always good to have.
More when the lot arrives.
Reply 31828 of 53137, by bearking
Had some time today to go to the local flea market and I got these:
100.85 KiB
A Matrox G400 32Gb AGP card
86.34 KiB
An Eicon Diva PRO 2.0 ISA ISDN modem. I bought this because I thought it is some kind of LAN card... Probably I'll keep it just for the collection...
130.09 KiB
An Ensoniq Soundscape Opus ISA sound card
116.79 KiB
A Creative Sound Blaster 16 Value CT2770
And also this socket 7 motherboard
151.02 KiB
It's a Sowah SR M504 C board. Basically it's a noname board, couldn't find any relevant info on it, only a 2 page pdf with the jumper settings and CPU support. It should be enough to test it... The board it's not in a very good shape, but for what I paid for it, It's ok. Supports CPU's up to 200 MHz, including dual voltage CPU's...
Also grabbed two socket A/462 CPU's, one Athlon XP-M 2800+ and one Sempron 2300+.
All these stuff for about 10 euro/11 USD! It's nothing spectacular, but for that kind of money it's a nice haul. I love these sunday flea markets...
Reply 31829 of 53137, by ragefury32
Received an IBM Thinkpad 560E from the friendly local mail carrier over the weekend...
file.php?mode=view&id=73841
The 560E is a very decent DOS/Win95 machine - Trident TGUI9682 GPU, Pentium 166MMX, 80MB RAM ceiling, ESS1688 audio, and with a throw-weight of around 4 lbs...not too shabby. This would have been the Carbon X1 of its day (1997) - it's light, well appointed and with decent specs. It's also quite good for gaming. The machine seemed to have visited the Thousand Islands region of New York/Ontario as it had a service sticker from Badhead.com, which is a tech shop located in Gananoque (a 20 minute drive from Kingston, Ontario and 30 minutes from Watertown, NY)
file.php?mode=view&id=73842
It's a curious specimen - the top case is missing (probably lost or broken), which gave this machine an Ono-Sendai Cyberdeck feel to it - Just have to hunt down some old Japanese Corporate/OpenBSD/Defcon stickers to give it that old hacker machine look. I actually prefer this look for now as the HDD is normally a royal pain to get to (it's supposed to fit on the lower left corner of the machine and under the top case/bezel). This is not the plan for very long, though. The 560s have a reputation for solder joint cracks on the inverter board thanks to chassis flex, and without the top case, this chassis flex will eventually kill the machine.
file.php?mode=view&id=73843
Unfortunately, in keeping with the current "post-modern sleeze" appeal of the machine, the entire thing smells like nicotine, much like my T21 (which took a keyboard swap and an aggressive wipe-down to eradicate). Fortunately the 560s are easy to strip down...
file.php?mode=view&id=73844
Well, I put it back together but for some reason the HDD is not detected. Then I realized what happened....the HDD cable (some piece of crap conductive flex cable) snapped - the inability to read the drive was reported as an issue on the original evilbay listing, but the diagnostics say that everything else is working normally. The original HDD is not quite healthy (it read data for up to 5 seconds then it'll lock up), but no one sane wants to deal with a 22 year old HDD. Oh well, the "plan B" parts machine I ordered is arriving within 2 weeks. In the meantime, setting up a 2GB MicroSD card and an SD-to-IDE adapter with a Windows 98SE install and getting it ready for use later.
file.php?mode=view&id=73845
Reply 31830 of 53137, by Stiletto
ragefury32 wrote on 2020-01-06, 05:30:
Yes! Great. Thanks for that Gibsonian reference, I deeply appreciated it. 😀
do the Fandango!" - Queen
Stiletto
Reply 31831 of 53137, by PTherapist
I was originally bidding on a Dragon 32 computer on eBay, but that went stupidly high so I didn't win. On a complete whim I decided to change tact (and money) and bagged one of these instead (random stock image from Google) -
Should arrive here later this week. My first retro purchase of the year.
Also ordered a "Just NANO SD" SD card reader/DivMMC device for my ZX Spectrum +2A. Long past overdue ordering one of these, I've been having to rely on loading .wav files through the cassette deck up until now. Having all the games on an SD card with instant loading will be a vast improvement!
Reply 31832 of 53137, by BSA Starfire
PTherapist wrote on 2020-01-06, 11:17:
I was originally bidding on a Dragon 32 computer on eBay, but that went stupidly high so I didn't win. On a complete whim I dec […]
Nice, the second home computer we had back in the 80's after the Vic-20, good little machine is the electron! I have a BBC Model B here with a MMC, it sure does make life easier! Hope you enjoy your new machine 😀
Reply 31833 of 53137, by PTherapist
BSA Starfire wrote on 2020-01-06, 12:13:
I'll probably get one of those SD Card interfaces for the Electron later this year, they definitely do make life easier. Until then I'll get by with loading tape images through the cassette port.
Reply 31834 of 53137, by dionb
luckybob wrote on 2020-01-05, 04:43:
@FluffyBunnyFeet
xjas wrote on 2020-01-05, 04:45:
Er, that's an IBM Model F 'AT'. The "AT" part sort of indicates AT spec, indeed this was the first AT keyboard. The fact it has indicator LEDs is another give-away: the PC/XT keyboard used a unidirectional protocol and didn't support indicator LEDs. This one does so is clearly an AT part using the AT protocol. Whatever else is wrong with it, it's not being an XT device.
See: https://deskthority.net/wiki/IBM_Model_F#IBM_ … ter_AT_keyboard
Reply 31835 of 53137, by gex85
When browsing eBay Classifieds the other day, an ad with a lot of mainboards and expansion cards raised my interest. In the original photos, the cards were piled so that most of them weren't fully visible, but there was one on top of the pile that couldn't be overlooked.
When I asked for more photos, I was pleased to find that there was acutally one more rare card in the lot.
190.06 KiB
Expansion cards (sellers photo)
Who can spot the cards that caught my attention? (One is very easy, the other one not too difficult either) 😄
According to the seller, most of the stuff should work (and there was quite a bit more in the lot that isn't in this picture) so I decided to get it for 55€ shipped.
My retro computers
Reply 31836 of 53137, by dionb
gex85 wrote on 2020-01-06, 13:42:
I suppose the V5-5500 and SB 1.5 are the two you're referring to. If either of them works, you've more than got your EUR 55 covered 😉
The AMD K5 and the ALi-based 486 PCI board aren't bad either.
Edit: what looks like a CT2910 SB16 is also nice.
Reply 31837 of 53137, by gex85
dionb wrote on 2020-01-06, 14:11:
Exactly 😄
I had previously identified the Sound Blaster as CT1350B (which would make it a SB 2.0).
The CT2910 is a nice addition, but nothing too special IMO.
The 486 board was actually one more reason to get this lot. I still need a decent board to go with the AT desktop case that I recently stumbled across, and this would probably fit the bill. A matching CPU should also be in the lot, as well as controller cards, VGA cards etc., so it will probably accumulate to a nearly complete 486 system. Would only need a proper hard disk (or go the Compact Flash route).
My retro computers
Reply 31838 of 53137, by gex85
As I previously wrote, I got in contact with a very nice seller who had dozens of expansion cards for sales on eBay Classifieds, for 1€ each (and he was serious about that). I initially contacted him for an Aureal Vortex AU8820, but by the time I wrote him the card was already sold to someone else. After having exchanged a few very nice messages with him, he told me that he had plenty more stuff that he wanted to sell. I asked him if he would mind sending me photos before putting everything up on eBay... so he did send photos of more cards that he wanted to sell!
Here's a photo of what I finally got:
554.55 KiB
expansion cards
Yeah, that's right, a Diamond Voodoo 2 12MB, complete with loop cable and an S3 Virge PCI.
And a Creative Voodoo Banshee PCI.
And an ELSA TNT2 M64.
And an ATi Rage 128 with TV-Out.
And various 3com network cards.
And a 2-port Compaq and a 4-port D-Link card.
And another Adaptec AVA-2904.
At 1€ each.
Since there has been a bit of discussion lately whether or not prices should be posted: I think that it is important to show that you can find good stuff for cheap if you are patient, lucky and friendly. You don't (always) have to shell out insane amounts of money to get your hands on nice pieces of retro hardware. However, I don't mean to start this discussion all over again, but wanted to make clear why I usually post prices, especially if I got something for cheap.
Coming up next: Lifetime supply of Pentium III Tualatin CPUs (from the same seller). 😄
My retro computers
Reply 31839 of 53137, by derSammler
gex85 wrote on 2020-01-06, 15:58:
So you already tested all cards and they all work? Because that's often the problem. People sell you crap even for high amounts of money. When buying whatever cards for 1€ each, I would expect that half of them are dead from the outset. If not, you're lucky, but never expect too much.
