Reply 320 of 2365, by m1919
- Member
wrote:Looks like Intel skulltrail? I hope you got it cheap... those things use a ton of power and run rather hot. […]
wrote:It's happening.
Waiting on this baby to get shipped.
[img]Looks like Intel skulltrail? I hope you got it cheap... those things use a ton of power and run rather hot.
It's weird seeing a desktop motherboard in a server chassis too. Totally "custom" job there.
I would think almost 99% that it's not the original motherboard for that chassis.
Got the entire the thing 280 CAD shipped. Considering these haven't appeared very often on ebay in working order that's not too bad.
Comes with 16GB DDR2 FB-DIMM, dual Xeon X5482s and a 1200W PSU.
No clue what brand the PSU is, I'll probably end up replacing it. Also won't be keeping the case.
Plan is to eventually grab a pair of X5470s, they have FSB 1333mhz and 10x multiplier. Should be able to get at least 4Ghz out of them, I would think.
Power usage is not a concern as this is not going to be running 24/7.
Crimson Tide - EVGA 1000P2; ASUS Z10PE-D8 WS; 2x E5-2697 v3 14C 3.8 GHz on all cores (All core hack); 64GB Samsung DDR4-2133 ECC
EVGA 1080 Ti FTW3; EVGA 750 Ti SC; Sound Blaster Z
