DOSBox Icon
Reply 320 of 333, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Welcome back 😉
See you in ten? 😉
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 321 of 333, by Duendeinexistente
Was bored enough to give this a twirl before bed. Tried to keep to old toylike aesthetics because let's be serious, this is for games. Maybe could've used less colors to make it easier to recognize at a glance?
1.42 KiB
EDIT: On further thought, let's get some good glossiness and some black edges.
1.62 KiB
Reply 322 of 333, by mkruer
Its been a long time posting to this Site... 13 Years? Anyway I thought I would post My idea for a newer DOSBOX icon. It is a more refined version of the DOSBOX in the MS-DOS 6.0 Style logo done above. I made the text work for BOX, but its a bit scrunched to get the over/under lapping to look, If you like it I might fidget a bit and see if I can pull it a part to keep the over under. I am also posting the Paint.Net file so others can play. Anyone should be able to squish and stretch and recolor the image. If at some point the icon is updated, I can look into making as SVG version.
5.94 KiB
    DOSBOX.7z
    11.82 KiB
    240 downloads
Reply 323 of 333, by Dominus
DOSBox Moderator
Generally looks nice, but the O of BOX seems not centered.
Reply 324 of 333, by mkruer
The issue is that X really doesn't allow it to fit through the O, it will either be fully on top or under the O, to offset this the O and X need to be fudged closer. Using the same source I created an oblate O this give the X more space to go though the O but the O is still offset to the right
2.13 KiB
This one has the letters a bit more scrunched together to make the O more centered
5.32 KiB
Reply 325 of 333, by Bruninho
mkruer wrote on 2020-04-13, 20:05:
I think it would be better the opposite way like it was done by this user:
Re: DOSBox Icon
JOBS, Steve.
Reply 326 of 333, by mkruer
Bruninho wrote on 2020-04-13, 20:21:
Re: DOSBox Icon
Can you clarify? X behind? X Ontop, Intersecting Fonts?
Reply 327 of 333, by Bruninho
That's pretty simple: An inverted variation of the original MS-DOS logo, with the grey words ("BOX") below instead of on top. DOS should get the coloured words instead, because it's the main product here, because obviously DOS stands for "Disk Operating System". MS (Micro$oft) is the secondary thing here, the focus is on DOS.
Sometimes the old MS-DOS logo was even used without the MS pairing, just DOS coloured. That's just basic product identity building practices.
JOBS, Steve.
Reply 328 of 333, by mkruer
Bruninho wrote on 2020-04-13, 21:04:
🤣 I looked the wrong Icon, for some reason I was looking at SieBoi Post. Yeah that icon would work as well, I was just looking at keeping the coloring scheme in the same place... If only this was called BOXDOS.
Reply 329 of 333, by Bruninho
Doesn't matter, as long as you keep the word BOX below DOS, it's "DOSbox". Just don't put it on top.
JOBS, Steve.
Reply 330 of 333, by JoeBlacksilver
I know it's not very retro or whatever. I was just making a DosBox icon for myself to go with the other sleek modern icons on my OS. Based on the original logo.
    15.25 KiB
    15.23 KiB
    11.95 KiB
Reply 331 of 333, by Bruninho
Black one does look great, might be even better without the red background or a version with the original MS-DOS colors; the 3D feel looks good.
When I have some time I might try to do a version for macOS Big Sur... the iOS icon look has never got me anyway, they are all the same. Current icons resembling real stuff on both macOS and Windows are better.
JOBS, Steve.
Reply 332 of 333, by JoeBlacksilver
I'm not sure if someone has made a DOSBox Icon like this yet. Can't find something like this on Google Images. Always wanted this icon for myself though. So I made it. Not the most original idea, but a timeless one I hope. (Actually, not sure if it's infringing copyright? Is that why no one has made something like this? Not that I'm going to make any profit from it at all.)
    1.48 KiB
