Reply 340 of 368, by Mike_
Yes, this is a thread for a different adapter, but there are also other similar projects. Such as my project NeoG mentioned. Unless you specifically want rio444's ISA card, I also have an extra prototype for that that I could send to somebody in EU. This is also quite easy to solder, as it has through hole components.
Internal PS/2 to serial mouse adapter (NEW: improved KVM compatibility)
The primary difference between these approaches is that PS/2 to serial converters need modified drivers for achieving low latency and being able to work with quirky KVM switches, but rio444's ISA card does not as it just pretends to be a serial port. The downside for rio444's card is that it's more difficult to solder, the chips need to be programmed (well, microcontroller in PS/2 to serial converters needs to be programmed as well, but AVR programmers are incredibly cheap on Aliexpress) and BOM is also a bit more expensive.
