Reply 340 of 644, by Oetker
- Oldbie
DoomSlinger wrote on 2021-04-15, 03:25:I've been having issues getting this program to find my card. I have an ES1869 card that's been integrated into the motherboard (old compaq deskpro) I add the parameter /CL and it returns two dots, I type in /R and it says it hasn't detected a pnp card. The card works fine in windows 98SE, however music WON'T play when playing any game through DOS 6.0 (I don't have 6.22 floppies and I haven't gotten around getting upgrade floppies made) and DOS 7 doesn't work either. Games I've tried: KQ6, SQ5, Hexen, SQ4 (sq4 actually does work if I select adlib audio when setting it up, but this only works with kq4, the others don't work with the adlib option, hexen works with cd audio) All sounds play fine in windows 98 (with some exceptions in KQ6 and SQ5 due to problems related to windows 98) the ESSCFG has not worked, or I haven't found the correct version, (downloaded the one here on vogons for es1869) in fact, using it disabled the speaker in the computer. Any ideas?
Edit: Forgot to mention the cpu is a pentium III 542 mhz, idk if that would make a difference, kinda new to dos.
These DOS drivers worked for me on a Compaq 1869 https://kentie.net/article/retropc/ES1869.zip
They might be the same ones you've tried.
The speaker in my computer doesn't work at all, you're saying you got that problem after running a wrong esscfg? Have you managed to restore functionality?
