Reply 34320 of 58457, by imi
- l33t
just putting a bit on the corroded spots should be enough to neutralize it, you can try to let it soak a bit where the corroded vias are, don't submerge it though.
then scrub it off with a q-tip as to not damage anything and then clean it with alcohol.
that's how I would do it at least.
