Reply 34540 of 57742, by kolderman
Technically you don't want/need to be grounded. You want to be at the same potential as the equipment you are touching. Touching the outside of a computer case or the metal bracket of an expansion card is usually enough. Static electricity is high on voltage but low on current meaning it dissipates fast those sorts of things without travelling to sensitive components.
