Reply 360 of 3179, by 5u3
shock__ wrote:
keropi wrote:
Argus is a very nice name IMHO , it has GUS inside and doubles as the name of a mythical ship 😁
*nod* Also argus-eyes (no idea if that figure of speech is well known internationally - but it's commonly used in phrases describing a requirement good eyesight/attention - which fits the first phase of the cloning process) - and last but not least greek mythology is something I like.
The term "Argusaugen" (argus-eyes) refers to the giant Argus, who was said to have 100 eyes.
ARGUS would make a nice acronym indeed, easy to remember since it includes "GUS". My take on writing it out would be "Advanced Reverse-engineered Gravis UltraSound. 😉
Reply 361 of 3179, by Stiletto
LunarG wrote:
Or how about Angus, "A New GUS"?
This one wins in my book 😁
do the Fandango!" - Queen
Stiletto
Reply 362 of 3179, by dogchainx
Angus....like Black Angus Steak Sandwich? darn it people, now I'm hungry.....
386DX-40MHz-8MB-540MB+428MB+Speedstar64@2MB+SoundBlaster Pro+MT-32/MKII
486DX2-66Mhz-16MB-4.3GB+SpeedStar64 VLB DRAM 2MB+AWE32/SB16+SCB-55
MY BLOG RETRO PC BLOG: https://bitbyted.wordpress.com/
Reply 363 of 3179, by jwt27
How about Revengus, for "Reverse-Engineered GUS"? 🤣
Reply 364 of 3179, by Synoptic
Final GUS ?
Reply 365 of 3179, by QBiN
Wait for it... https://youtu.be/t7kgL86x5Tc
Reply 366 of 3179, by shock__
Being *dun*dun*dun* vegetarian myself and the spelling very similar to Agnus (a custom chip in the Amiga homecomputer) this certainly wouldn't be my first choice.
My current favorite is ARGUS or AREGUS - while AREGUS isn't the correct spelling it goes well with "advanced reverse-engineered GUS" and "are" implies an effort by multiple persons (since this project would have had a way longer turn around time without all contributors/donors)
EDIT: 10.000 Thread views! Wheee 😀
On the productive side: I've finalized the via stitching on the board and will start to add headers soon - but first I'll finally solder my SSI-2001 card today, such a shame it has been lying here as a kit for over a month.
Current Project: new GUS PnP compatible soundcard
[Z?]
Reply 369 of 3179, by brostenen
How about "The Skunk-G" as in Skunkworks and GUS?
Reply 370 of 3179, by shock__
Slowly getting back to the project after I got sidetracked a bit building the SSI-2001 and revisiting my DSS reversal.
- started adding the ISA-headers aka "magic smoke escape hatches" in case anyone thinks they're jumpers ^^
- On the namefinding side, unless someone has a good reason why ARGUS (advanced reverse-engineered GUS) shall not be the name for the project I'll take that one.
[Z?]
Reply 371 of 3179, by j^aws
For the name, I don't think it matters in the end. But for the sake of a counter argument, a GUS follows a format:
GUS Classic
GUS Max
GUS Extreme
GUS PnP
GUS Something
etc...
These roll off the tongue better...
Reply 372 of 3179, by dogchainx
j^aws wrote:
For the name, I don't think it matters in the end. But for the sake of a counter argument, a GUS follows a format: […]
GUS Classic
GUS Max
GUS Extreme
GUS PnP
GUS Something
etc...
That's why I suggestion/supported ARGUS Shockwave. Not my idea on either name BTW. I just liked the sound of them together. 😎
Reply 373 of 3179, by shock__
A wild prototype appeared!
http://i.imgur.com/JwymKK6.jpg
It's very effective!
(making sure the clearance for the prototype headers isn't too close to the actual slot and the joystick/audio jacks work with the same kind of donor brackets Fagear used for this SSI-2001 replica project).
EDIT: Hacked up a logo from hard1k's incredible revectorized UltraSound logo.
Works quite well for me: http://i.imgur.com/Du7D3pr.jpg
[Z?]
Reply 375 of 3179, by Kodai
Perfect and period correct looking logo.
Reply 376 of 3179, by hard1k
I think the logo is just great!
As far as the ISA header is concerned, I'd like to come up with some suggestions once more 😀
Have a look at this wonderful thread by jwt27: Short on ISA slots? Try this.
Maybe you could split up the header in blocks just like he did for his ISA-header PCB? This way we could later use ARGUS as a universal ISA riser.
Another really cool and useful feature would be an onboard supply of -5V current to the ISA bus (again based on jwt27 schematics from the same thread). If incorporated, it would make up for the -5V line that is absent in all modern power supplies, but still needed if a LAPC-I or CT1920 is installed. Of course, if you decide to implement it on the PCB, then a jumper should be put there as well (for people that still use PSUs with -5V). All this could be made just as an option for those who need it - just leaving it all unsoldered in the final product.
Personally I would be very grateful if you decide to implement this 😀 I hope I'm not alone.
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 377 of 3179, by shock__
Thanks 😀 If you could hack up your vector symbol you did in eagle that would once again be largely appreciated - the logo shown above is just a 5 minute photoshop hack with the G build from the letters O and U 😉 In case it helps, I identified the font used for the GUS part as "Univers Exp" or "Nimbus Sans Extended Regular" (prefer the first because it has a simpler G).
That's basically what I did yesterday 😀 That way one could either design a daughterboard for the ARGUS (i.e. with SoundBlaster compatible hardware) or use it instead of the $25 riser card. The 64 pin connector will have to be cut short of 2 pins tho (ISA8 is 62 pins) - not a big issue tho, just leave 2 pins unconnected.
Works for me 😀 Especially since that area of the ARGUS PCB is quite blank since I moved parts around a bit for implementing the headers. Actually considered making a -5V supply a small side project of it's own, but yeah - totally makes sense to include it as an option. Even when the card actually derives it's own -5V supply from the -12V rail.
Thanks for the suggestions 😀
[Z?]
Reply 378 of 3179, by wbc
Nice logo 😀
about onboard ISA -5V rail: good idea, but of course with disabling jumper (all my PSUs have -5v rail 😉)
--wbcbz7
Reply 379 of 3179, by hard1k
As that original work was done by hyperborean, I guess his help might be useful.
AWE64 Legacy
