Reply 360 of 372, by mmx23
- Newbie
bofh.fromhell wrote on 2025-11-24, 23:40:Sweet! Also have that MB rev 2.1 with box and manual! Now I need to add a socket 8 slotket to the wishlist. Cant wait to run a P […]
mmx23 wrote on 2025-11-24, 08:17:I'm proudly present to you one of the first Pentium 2 motherboards, AOpen AX6F, who is using Intel's 440 Fx chipset. When used […]
When used with a Pentium Pro processor on a slotket, it will hand right after HDD detection.
@DenizOezmen managed to mod the BIOS regarding L2 cache control. He changed that part of the code to support a Pentium Pro.
Now I can use my board with a Pentium PRO cpu.The bios can be found on his webpage at Other Patches.
https://oezmen.eu/bios/Thank you Deniz for all your help!
Sweet!
Cant wait to run a PPro in an FX chipset MB!.......hey waitaminute!
Glad to hear you have the same MB.
But pay attention to the Bios size.
https://theretroweb.com/motherboards/s/aopen-ax6f
Here you may find all original bios releases and if you look closely only R1.10 and R2.0 are 1 Mbit in size.
All the rest are 2 Mbit bios-es, so not sure if my revision will work properly on your MB. Forgot to mention that my MB is using R2.0 Bios version.
But, you can PM Deniz and he will be glad to help you to mod your specific bios version.
Of course you will need a Slotket 8 to use a Pentium PRO, I've used a slotket from my ALR Revolution 2X server for this.
Is worth to check with @Mentat-vvo if he still has one for sell.
