Reply 360 of 950, by feipoa
- l33t++
Ran v6.1.0 on an SXL2-50 system with ALi M1429 chipset.
1) HWiNFO hangs after leaving the ISA/VLB "other devices" section. The Info menu is displayed with Mainboard info highlighted during the hang.
2)The Cirrus Logic CL-GD5428 doesn't show up in the ISA/VLB section but shows up under video information.
3) IRQ assignment correctly shows the AHA-1522B installed, but under SCSI Host Adapter Information, it is listed as the AHA-1520. This system is using the 1522B.
4) Math Co-Pro speed is listed correctly, but the speed is shown as 27.5 MHz. Should be 25 MHz.
