Reply 3600 of 57738, by m1919
- Member
Sealed retail boxed Intel SBT2.
Didn't consider this at first, but the front panel connectors are proprietary. There's also some kind of proprietary 10-pin connector, I believe it's required if using a redundant power supply. No idea if it's actually required to boot the board or not. Apparently the board is intended to be used with the Intel SC5000 pedestal case, but I got other plans for it.
Possible specs:
Dual 1Ghz P3 Xeon SL4HF
4GB PC133 ECC
3DFX Voodoo5 5500 PCI
Sound Blaster Audigy
Dual 36GB Quantum SCSI drives
Sealed Sapphire Radeon X1950 Pro AGP
ASUS PC-DL
Came with a pair of 2.8Ghz Xeons, but I picked up a pair of 3.2Ghz on the cheap, the best this board will officially run. Unfortunately this board only officially supports 533Mhz FSB, but I can probably OC it a bit.
Crimson Tide - EVGA 1000P2; ASUS Z10PE-D8 WS; 2x E5-2697 v3 14C 3.8 GHz on all cores (All core hack); 64GB Samsung DDR4-2133 ECC
EVGA 1080 Ti FTW3; EVGA 750 Ti SC; Sound Blaster Z
. The IDE HDD I had in my childhood 80286. It is lightning fast compared to the ST-157A that I had in the childhood PC I found and bought a while ago. It also makes very little noise in comparison. Plus it is natively supported by the BIOS.
