Reply 36260 of 60117, by yawetaG
mpe wrote on 2020-10-01, 18:07:
Another addition is these two Trident cards. Cosmetically, they've seen better days. […]
I've been asked to include some Trident cards in my VL Bus Card Group Test. I'll have to do some research about them and still wondering if 9400CXi and 9440AGi are the best representatives of the series. I suspect there won't be much difference and no reason to look for 9420 9200 or other types.
9400CXi should support interlaced modes, up to 2 Mb of video RAM, and Windows GUI acceleration. IIRC, the official drivers and utilities (which should be in the Vogons driver library) also support a nifty extended desktop in Windows 3.x, and there's also a utility to get SVGA modes in pure DOS...
Reply 36261 of 60117, by vmr_
Who's who? Beauty and the Beast...
Retro builds & sandbox
IBM XT 5160 | 286 | 386 | 486 | S4 SI5PI AIO & S4 Batman + P60 SX828
S8 & PPro 200 | SS7 FW 5VGF & Asus P5A & AOpen AX59PRO K6-III+ 550MHz
Asus K7M Athlon 1Ghz GDF | Abit SH6 Pentium III 1GHz SL4KL...
Reply 36263 of 60117, by EvieSigma
Is that...an Amiga Zorro II(?) networking card?
Reply 36264 of 60117, by dionb
kolderman wrote on 2020-10-03, 05:44:
Doesn't get much better than this.
Anyone know if opl4 daughterboards were ever made?
Probably not as they weren't standalone MIDI synths the way others on daughterboards were. That's also why they don't work under DOS, they need more software support than just sending MIDI instructions the way most chips work.
Reply 36265 of 60117, by liqmat
wiretap wrote on 2020-10-03, 19:39:
Picked up this with my Ebay bucks today. […]
I had one of those in my Amiga 2000HD in the late 1990s. Perfect for my FTP needs.
Reply 36267 of 60117, by cyclone3d
dionb wrote on 2020-10-03, 21:00:
The was some company that made them... Site is still up but they don't respond to inquiries... And the address on their site shows a boarded up building.
Also pretty sure there is at least 1 OPL4 card that has working DOS midi.
EDIT:
Here is the company that used to sell the OPL4 daugterboards:
https://scientific-solutions.com/surplus/part … /opl4/opl4.html
And more about YMF278 vs YMF704
The YMF704 OPL4 mistery
And some more info about the cards that support GM through DOS... or at least it sounds like they do:
http://www.os2museum.com/wp/44-voice-midi-on-yamaha-opl4/
The OPL4 chip itself did not directly respond to MIDI data and had to be driven by software (or firmware). Some cards, such as the Audiotrix Pro, Logitech SoundMan Wave, or miroSOUND PCM12 and PCM20, included a microcontroller which enabled direct MIDI playback over the MPU-401 interface.
Yamaha’s own SW20-PC provided a software driver for DOS enabling MPU-401 playback.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 36268 of 60117, by EvieSigma
I somehow found retro (well...the Dell isn't quite so retro, but it's over 15 years old now so that counts for something) computers today going out to yard sales and the local flea market. A Dell Precision 340 (Socket 478 with RDRAM) and a Compaq Presario 5340 (CPU currently unknown, haven't tested it yet and it doesn't have a helpful sticker). How the heck do you actually reach the motherboard on these Presarios, do you have to remove the power supply?
Reply 36269 of 60117, by Shreddoc
cyclone3d wrote on 2020-10-04, 01:14:
I have an Analog Devices based ISA card with also the OPL4-ML chip, or YMF704C-S (datasheet available at) with 1MB GM sample set - on the card itself. This old thread shows how daughterboards based on that chip variation also exist(ed). See also this old thread.
The other (or perhaps more accurately, main) OPL4 chip variant was the YMF278B (PDF data 4.7MB) whose GM sample set was, at 2MB, twice the size of the 704C, and which I believe had potentially more flexibility in terms of bank configuration, accessing external RAM etc. More capable, basically - the "flagship" version of the OPL4 lineup. I believe (as per reasons below) you will only find this chip on soundcards themselves, and not on separate daughterboards.
A factor noted in the 704C docs is "contains an interface which is compatible with MPU-401 UART mode". I may be misconstruing this, but I believe it indicates how the 704C was used more extensively (if not exclusively*) when it came to "OPL4"-based daughterboards, because that inbuilt interface (and the omission of the 278B's more featureful ROMplering) enables a simple partnering with third-party cards via the standard waveblaster connection.
*To add further complication there is also the YMF721 aka the OPL4-ML2 (PDF data 461KB), which seems to essentially be an updated "V2" of the 704C. Again with 1MB sample set, and MPU-401 UART interface compatible, and designed to greater simplicity + lower cost than the 278B. So I suspect that these -ML chip variants - the 704C and the 721 - are what you will find on all "OPL4" daughterboards.
I hope this information aids your search.
Reply 36270 of 60117, by PTherapist
EvieSigma wrote on 2020-10-04, 01:56:
I have a Compaq Presario from roughly the same era (mine is a 5420) so if it's similar inside then the PSU may be on a bracket that you can unscrew and slide out of the way, allowing you to reach the motherboard without having to remove the PSU fully. Those cases are extremely snug inside and can be a pain to work on.
Reply 36271 of 60117, by dionb
Yep, that was what I was referring to. Wasn't aware someone stuck the microcontroller on a wavetable board though.
Makes me wonder though: would it be possible for SoftMPU to support OPL4 the way it does Emu8k?
Reply 36272 of 60117, by kolderman
dionb wrote on 2020-10-04, 09:35:
SoftMPU supports emu8k? As in talks to the aweutil /em:gm tsr?
Reply 36273 of 60117, by EvieSigma
PTherapist wrote on 2020-10-04, 09:22:
That seems to be the case, yeah, but man is that annoying!
Reply 36274 of 60117, by Intel486dx33
I just pick up this little guy from the scraper.
Its a Gateway 2000 with Pentium lll @ 933mhz.
It was designed for WinME but should work fine with Win98se too.
A little TLC and it should be fine.
Reply 36275 of 60117, by Joseph_Joestar
Intel486dx33 wrote on 2020-10-04, 16:22:
I like the case. Front USB ports that aren't placed at the very bottom are a rare sight among 90s era cases.
For various reasons, I prefer keeping my PCs on the floor and not on my desk. So having easily accessible front USB ports is something that I highly value.
My retro stuff
Reply 36276 of 60117, by Intel486dx33
Joseph_Joestar wrote on 2020-10-04, 16:34:
Yeah, I have a few Gateway 2000 computers from the 1990’s. This one is actually from 2001 but I have another one in the same style case from 1999. I really don’t like the 486 gateway computers as they where loud and difficult to work with.
This model works fine they just need a rear case fan.
This was one of the last American computer companies who’s height was in the 1990’s.
Reply 36277 of 60117, by brostenen
Just bought two nice things for my SixtyClone machine.
The first is an original VIC-II video chip. It is an 6569 Revision 5. One of the best longboard chips out there. I think it is only the Revision 7 that are better, yet the price diference makes the R7 a no-go. Also. My SixtyClone is an 250466-board, and they came with an R5.
The other is an ARM-SID. The quality is close to the original breadbin SID, and the original Model-C boards (shortboard), sounds crappy compared to the ARM-SID. Plus I want to create a C64 with the use of as many modern parts as possible. I can't wait to see what the FPGA-VIC-II and FPGA-CIA chips will be like.
There is a video about the ARM-SID here.... (I am convinced that it is worth it, when looking at original SID prices and FPGA-SID prices)
https://www.youtube.com/watch?v=mmlIhfqN43o
Reply 36278 of 60117, by Intel486dx33
I am going to rebuild my Intel x86 version of the Sun Solaris workstation from 1990’s.
Intel DK440LX motherboard with Dual Pentium 300mhz CPU’s.
Maybe Win2000.
Reply 36279 of 60117, by Robin4
Turbo -> wrote on 2020-09-30, 07:49:
Bought this early Pentium 4 computer case, but I think I can get away with installing a higher-end Pentium III system, judging by its looks, which was my primary goal why I bought it.
Iam using the same case for my Pentium III 550Mhz machine. I like it very much for what it is.
