Reply 3700 of 31380, by orinoko
- Member
wrote:Wow, so it's not just a fantasy lineup - you have these machines for real? Would love to see a pic of the actual articles too. The attention to detail is incredible, like the line of light leaking in through the case of the far-right IBM that's visible through the grille.
Yeah these are my machines 😊 This doesn't even scratch the surface, although most of the other machines are 'just' generic PCs... amongst a few iconic machines too. Which I'll model too...
I'll take some photos of my little work area soonish, ended up cleaning the house, as one does at 11pm on a Friday haha
The machines in that render still need a lot of extra detail added, and the light you can see through that PS/2 probably isn't normally visible because of the hardware inside. I might model parts of the internals, or I might just block that off so light doesn't leak through like the real thing...
Edit: thought I'd throw up a link to a large render I did too. Also, if people want this discussion moved out of this thread, please say and I'll do that 😀
https://www.dropbox.com/s/27mdgiijjycy3t3/201 … 51701a.png?dl=0
