Reply 380 of 407, by Trashbytes
- Oldbie
such wrote on 2026-04-21, 00:00:More than likely they reserved more than they actually need considering they can't power on whatever data centers they currently […]
Trashbytes wrote on 2026-04-20, 00:13:sunkindly wrote on 2026-04-19, 16:19:I just noticed the same 4TB Samsung 990 Pro is now $1000 and I paid $300 for it last July. Holy crap. Did price increases hit SSDs worse than RAM?
Yes, because the AI bros need Nand storage for some reason, the likely reason is hoarding of current supply as the Fabs are not producing as much Nand as HBM is worth more and both ICs require the same production lines and materials to produce.
More than likely they reserved more than they actually need considering they can't power on whatever data centers they currently have while building so many more...
Anyway, it should also be added that HDD prices are getting silly at this point, and there's been some rumblings regarding CPU supply every now and then. Some GPU price increases, but not too bad all things considered. For now, at least.
This is the time to enjoy what you have. And to take very good care of it.
HDDS are a very different beast to SSDs in regard's to production and HDDs got hit hard with the war going on in the Middle East, they need helium to produce the enterprise level HDDs and with Israel being the majority producer of electronic grade helium, the supply of it is exceptionally stretched. Other countries supply helium but none of them can supply the capacity Israel was.
Im sure the AI bros have also reserved more spinning rust drives than they need and can actually use so that is also straining the already reduced supply.
