PowerVR Fun Thread
Reply 380 of 1104, by Stiletto
lolo799 wrote:
I can do it next week if you are still looking for it.
Great, thanks again!
do the Fandango!" - Queen
Stiletto
Reply 382 of 1104, by Stiletto
leileilol wrote:
I noticed that this is no longer fun
swaaye's been doing this, dunno why. *shrug*
Stiletto
Reply 387 of 1104, by subhuman@xgtx
Stiletto wrote:
Attached: "The Archaeology of PowerVR", also known as "The Early History of PowerVR"
Extremely educational. I hope this will be conserved for years to come.
Big thanks both to you and the author. I'd love to see more about the Midas arcade/developer hardware. Also to you Lolo for uploading the M3D cds 😀
Reply 388 of 1104, by Stiletto
Well, I didn't exactly ask permission, but hopefully he will think it's okay. He still retains his copyright.
Not sure how or why we had it, though it seems as if it used to be public.
[EDIT] Actually, it's going away. Sorry about that.
Stiletto
Reply 391 of 1104, by Stiletto
Quoting myself in another thread - I'd love to someday see a copy of the Neon250 driver CD, high-res PCB scan and a dump of the video BIOS! 🤣 (Perhaps NitroX Infinity has already done this and I haven't been paying attention.) With Dreamcast/NAOMI being emulated, perhaps a Neon250 emulation might not be all that difficult to add to MESS or Bochs or even DOSBox should someone be properly motivated... and more testcases for Dreamcast video emulation is always a good thing 😀
Stiletto
Reply 393 of 1104, by Putas
Does this mean it should not be exposed? Like if I would want to enrich article on my web...
Reply 394 of 1104, by Stiletto
I've been asked by the author to no longer share it. This extends to others.
Stiletto
Reply 395 of 1104, by leileilol
Koolsmoky's PowerVR PCX2 Control and Advanced Setting patch were a bit hard to find...
    advanced.zip
    2.46 KiB
    116 downloads
    pcx2ctrl.zip
    115.15 KiB
    108 downloads
long live PCem
Reply 397 of 1104, by leileilol
UT GOTY 432 has worse lighting than UT 400 for some reason, but anyway:
Install KernelEx.
Uncomment the lines in SGLDrv.int
Hexedit SGLDrv.dll, look for appPow, change those MMMMM's into NNNNN's (forgot which way around was this)
Run UnrealTournament.exe in default compatibility mode (still lost on why KernelEx affects SGLDrv to function....)
Select PowerVR SGL for Windows
you should then see this.
long live PCem
Reply 398 of 1104, by d1stortion
Doesn't work 🙁 refuses to start. I removed those slashes in SGLDrv.int and changed "appPow@@YAMMM@Z" to "appPow@@YANNN@Z" in SGLDrv.dll, did you forget anything else maybe?
Now it showed the following: critical error, assertion failed, WinClient.cpp line 354 a.s.o.
