Reply 380 of 929, by FreddyV
zyga64 wrote on 2020-04-09, 08:59:When first module I'm trying to load is Time... by Fugaz / ByteLand (16 channel s3m module) this module plays correctly and every other s3m after it also plays correctly.
But when I'm trying to load at first another s3m, for example Bad Weather by Well / Obfuscation I cannot play it until I load one of "good" s3m's. No matter which mixing frequency I set for this particular module. I didn't noticed this on b16. So far every 4 channel mod I've tested sounds good, everytime.
Hi,
I will test this.
I have an S3M module that did this as well, it is still in the known bug list.
But I "Forgot" To debug it.
Some internal variables are not set correctly sometimes 🙁
Edit: I tried under DOSBox and I can play Times after Bad Weather. What do you mean by you can't play it anymore ?
