Reply 3800 of 60122, by PeterLI
Thanks!
Thanks!
wrote:These two Quadro GeForce4 cards arrived: […]
Not sure when I get a chance to play with them, my retro room is, once again, a mess 😵
Nice! Looking forwards to how those do with Splinter Cell (and other games). 😀
And I agree on the PSU thing - most of my retro builds use hilariously oversized PSUs because they're generally not much more money and provide a lot more flexibility in terms of re-using the PSU elsewhere and/or the freedom to add whatever expansion card/device you can dream up. 🤣 I've also noted that if the PSU is relatively efficient (especially if its 80+, but the "not quite" models in the 70-80% range aren't bad either) it usually does better (in terms of how much power is actually drawn from the wall) than the original "small" PSUs as some of those tend to only be ~50-60% efficient. 😵
wrote:Nice! Looking forwards to how those do with Splinter Cell (and other games). 😀
I tried both cards last night and they work fine! I installed the same ForceWare driver as with the GeForce (I didn't know ForceWare included Quadro) and the game works fine. All the shadows check out and performance is also fine. Can't tell much of a difference, maybe a little bit smoother compared to the GeForce 4800 SE.
wrote:wrote:Nice! Looking forwards to how those do with Splinter Cell (and other games). 😀
I was actually thinking about the Quadro/GeForce thing the other day, and looked at the release notes for older ForceWare releases and they do tend to list Quadro. I think it's a more recent thing that they're using "separated" drivers. Good to hear that they work well for the game as well - adds more options that don't have "odd" performance.
wrote:wrote:These two Quadro GeForce4 cards arrived: […]
it;s better to have a PSU that is more than you actually need due to deterioration over time. Eventually they no longer provide the proper voltages across all rails and you start having problems. Yes, they make PSU's that are guaranteed to maintain 80+ or 85+ efficiency for long periods of time but you pay more for those. Starting with a PSU that is overkill in the first place achieves the same goal and sometimes for a lower price than a high efficiency PSU.
i also have a sw60 xg card floating around in my cellar, but i saw a person making into a standalone Midi-device on you-tube, so i thinking doing the same with mine 😀
found the video 😀
https://www.youtube.com/watch?v=k3DrNlqle1A
wrote:it;s better to have a PSU that is more than you actually need due to deterioration over time. Eventually they no longer provide the proper voltages across all rails and you start having problems. Yes, they make PSU's that are guaranteed to maintain 80+ or 85+ efficiency for long periods of time but you pay more for those. Starting with a PSU that is overkill in the first place achieves the same goal and sometimes for a lower price than a high efficiency PSU.
If you've got a PSU that's so aged/defective that it runs out of spec on the voltage rails, it should be repaired or recycled - it's no good for hardware if the rails are sagging or running too high. Buying something that was over-spec'd in the beginning won't really mitigate that problem - everything eventually ages and fails. 😢
As far as the efficiency bit: in general I'd have to disagree with you. 80Plus units are very much the rule rather than the exception these days, and shouldn't be shied away from - running a less efficient and over-spec'd model will usually never approach the efficiency capabilities of an 80Plus unit (let's assume we go find some old-school boat anchor that runs 60-70% efficient and we only load it around 20% (and this isn't an unrealistic scenario) - it's going to run at the bottom of its efficiency curve pretty much consistently, so let's say we're talking about a 1kW model and we're pulling 200W out of it at 60% efficiency, which means there's better than 100W (!!) of waste power that's going to be expressed as heat by this unit; contrast that to say, an 80Plus Platinum unit that will run at 90% efficiency or better across its entire output range, and put that same 200W load onto it, and we'll see around 20W of waste power/heat generated for the same setup - the savings on power don't just help at the wall, it also means a lot less heat that has to be dealt with by the system).
Bought this thing : http://museum.ttrk.ee/th99/c/I-L/21052.htm
And an PCMCIA FAST-SCSI card with cable.
In fact, if you're buying a brand-new PSU, I would make an even bigger statement: do not buy anything that isn't 80Plus certified. Why? Because not only are non-certified PSUs less efficient, they're also a lot less well built, and will almost certainly be overrated - sometimes by a huge amount. It is not possibly for a 80Plus PSU to be overrated, due to the way the tests work. An 80Plus PSU will almost always last longer, be more efficient, and be a lot kinder to your components as well.
I just bought this 😀
Some more Nexgen stuff arrived yesterday, this time a whole system. It's a PCI motherboard and an unknown speed nx586. I had to take the CPU out because even though the rest of the system was clean, there was a lot of dust stuck on the fan, in the fins of the heatsink and on the surface of the chip. It's one of the ones that doesn't have the speed silkscreened on the chip so I'll have to add a hard drive to the system and boot it to see what speed it reports. This is now my 5th Nexgen motherboard and CPU. I have 3 VL-Bus boards and now 2 PCI. Only one other person I know of now has more Nexgen boards than I do, and that's a man in Germany who has 9(!) VL Bus and 1 PCI and he lists the serial numbers of his on his website and none of his match any of mine so I assume his collection is still intact.
Got this in from CA today. Works great.
wrote:Got this in from CA today. Works great.
Uhm... You don't need this give it to me! 😀
There is a lot of Roland in DE as well. Try www.dosforum.de. 😀
wrote:There is a lot of Roland in DE as well. Try http://www.dosforum.de. 😀
Yeah, i know about that board. But i prefer Vogons. 😀
Of course. However: Vogons does not allow buy & sell. 😀 DFDE does. 😀
Not really retro.. But when looking some video on youtube i find that there where SMD soldering practice boards..
Because i never solderd that kind of type, and it wasnt very expensive so i really want to give it a try. Hoping my soldering skill could upgrade.
Won a CT1600 Sound blaster pro 2 (untested)
Some soldering tips for my weller soldering station.
wrote:Korg AudioGallery AG-10
Cool. How does it sound in comparison to an SC-55?
Scored an SGI 550L Visual Workstation.
I have no real interest in the case, just the hardware inside. Board is an M29A based on the i840 chipset. Runs 133Mhz P3 "Xeons."
Hopefully I didn't bidsnipe anyone on here 🤣 for this.
http://www.ebay.ca/itm/161287048990?ssPageNam … 984.m1497.l2649
Crimson Tide - EVGA 1000P2; ASUS Z10PE-D8 WS; 2x E5-2697 v3 14C 3.8 GHz on all cores (All core hack); 64GB Samsung DDR4-2133 ECC
EVGA 1080 Ti FTW3; EVGA 750 Ti SC; Sound Blaster Z
