Reply 40 of 58, by majestyk
Maxvintage871 wrote on 2024-05-02, 23:28:
...voltage to the tab of either Q2 or Q3 results in the 3.57v output of the transistor (same measured on both or 2.49 volts for the vcc2 transistor with mmx settings).
2.49V for the MMX (P55) setting is way too low. This should be 2.8 - 2.9V.
There´s definitely something wrong in the VRM circuit.
Reply 41 of 58, by Sphere478
majestyk wrote on 2024-05-07, 05:12:
That is low for a board setup for p55, agreed.
But I would note that I have regularly ran MMX chips at that voltage (and lower) stable every time it seems at 233. So, p55c is usually stable at that voltage. Depending on clock speed and temp.
There are p55 mobiles specced at 2.45v btw.
Sphere's PCB projects.
Reply 42 of 58, by Nexxen
Sphere478 wrote on 2024-05-07, 16:09:
That is low for a board setup for p55, agreed. […]
It could indicate the inability to generate 2.8V and correct amperage.
Had that recently.
As I desoldered components V got up but no go.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 43 of 58, by Maxvintage871
Hello,
Address lines A0-A2 on the BIOS using the Post1A does produce what looks like very healthy signal, for only 3 seconds, then flatlines. It is a full 3 seconds on a cold start and less than 1 second on reset. There is more interesting signals on A0 and A1, A2 is a much lower frequency.
Please let me know if you think this leads you to another test? Maybe the CPU is signaled to halt or maybe the cpu is producing the hold signal
Thank you!
Reply 44 of 58, by rasz_pl
This is great bad news, so the CPU crashes, somewhat explains glitchy postcard output. Now to "only" figure out if its the CPU or chipset making it crash.
Can you capture CPU Voltage rails during this 1 second just after reset to see if its messy, zoom in as much as you can. Optimally you could probe directly on the back of CPU socket. Would be interesting to see A0-1 and D0-7 CPU pins including their logic levels. Maybe its CPU Voltage regulator after all giving CPU so little power its barely able to drive Address bus, and not data bus at all so outputs are misinterpreted.
Reply 46 of 58, by Sphere478
rasz_pl wrote on 2024-05-09, 01:44:
If it’s the power, a easy test is to just inject power from a bench top psu. Probably just leave onboard power active and just parallel it.
In my projects in sig I have some interposers which could be used to power separately. But not really needed to do the test.
Reply 47 of 58, by Maxvintage871
First, after staring at a pinout of socket 7, I have no idea where A0-A2 are located. Please let me know if I'm just missing those pins.
I can find A4 and above. I can also find D0 and above, which is what I tested below. The CPU is a standard Intel P133 and the jumper settings are set correctly where VCC2==Vcc3==3.6 volts.
I measured D0 directly at the pin on the bottom of the board. I am using the Post1A bios. I have attached a video that you can see the D0 interesting data (this is 3 seconds after cold boot, but my video editing skills are lacking). At the 3 second mark, the voltage flatlines. I also included a higher res photo of the data line. It looks like we are getting pretty close to 3.35 vmax on D0 which would stand to mean that the voltage regulation is likely not the issue, right?
I was curious as to what the HOLD pin reported on start up. I took another measurement and in the same 3 second time we go from a lower frequency pattern to a higher frequency pattern. I attached that video as well.
Based on those 3.35 volt and the 3.6 volts I'm seeing, I don't think the cpu is running undervoltage. Any other ideas?
Reply 48 of 58, by rasz_pl
>Hold Pin on Start Up.zip
pin E-15 is going high after 3 seconds?
At first its ~15 microseconds like standard ram refresh, except ram controller is not configured so what gives? is Intel chipset always running its refresh circuit no matter what?
After that screen/scope is aliasing so cant tell, but possibly at bus speed?
That is weird and beyond my knowledge. AFAIK nothing in a PC should be able to take over the bus on its own just after power on. Maybe someone else will have more ideas.
Garbage on post card + hold might be flaky southbridge. Have you looked (poked t with toothpick under magnification) at all the pins of two big Intel chipsets?
Reply 49 of 58, by Maxvintage871
I do have a microscope. I can check the pins on the chipset chips.
I did gently scrape a pick across the pins and didn't hear anything that would lead me to believe there were loose pins.
I will update as soon as I can check the pins.
Reply 50 of 58, by Maxvintage871
Hello all,
Thank you for suggesting to look in the microscope at the chipset. It turns out the large chipset chips are fine. I attached a picture of 75% of one of them just as an example, but nothing was out of ordinary there on either chip.
I was giving up in despair so I removed the CPU to put the board away into storage. That is when I remembered that putting the CPU into and out of the socket 7 was somewhat difficult. No pins are ever bent when changing the cpu, but the zif socket should have no resistance whatsoever. There was a bits and bolts youtube video that reminded me about damage to the socket: https://www.youtube.com/watch?v=EkRdjnAhA0w&t=341
So, I put the socket 7 under the scope and I think 2-3 pins are bent ( https://youtu.be/sTLeR0fGStQ ). However, I think they are just VCC3 pins so I don't know if missing connection on those pins would cause anything to be amiss. While reviewing the video I think a VCC2 pin might also be bent on the side nearest the socket arm.
I have no idea how to pull the socket 7 apart so I could inspect under the upper cover. I could try to replace the entire socket. Any suggestions?
Thanks!
    570.97 KiB
Reply 51 of 58, by Repo Man11
If you very carefully pry the edges of the socket's top cover (using something like a very small flat screwdriver), you can lift it off. I've done this on both Socket 478 and Socket 370 boards.
Reply 52 of 58, by Maxvintage871
I carefully tried and could not free the top half of the zif socket. I desoldered the entire socket and it was easy to remove the top of the socket from the bottom. I have a video of the pins without the socket top (https://youtu.be/Fs6VAIaamgE). There are at least 3 bent pins. It is a good thing I removed the top as I can pull the entire pin out, straighten it and put it back in. I just hope the bent pins had something to do with the behavior that was found.
Reply 53 of 58, by Maxvintage871
Just a quick update. I broke a pin that needs straightening so I bought a new socket 7 from Phoenix Enterprises connections. Very reasonable price. Once it comes in I will update again with some photos of the resoldered socket and if that fixes the problem
Reply 54 of 58, by Maxvintage871
The new socket is in and there is no change at all. That might mean that the socket is well soldered as the condition didn't get worse.
I think it might be best if someone else gives it a try. Would someone here would be willing to have me send them the board and continue the post? I will cover the packaging and shipping.
Reply 55 of 58, by Nexxen
Maxvintage871 wrote on 2024-05-28, 21:16:
Add where you are from.
Maybe Necroware? If anyone could ask him.
Reply 57 of 58, by Sphere478
Maxvintage871 wrote on 2024-05-20, 00:27:
Basically almost all of the outer pins are power pins. You can loose a few and still be working.
Video isn’t playing all the way bad signal did I get the gist of what you found?
Reply 58 of 58, by Maxvintage871
Scoping a0-a2 does show good signal for 3 seconds on cold start, 1 sec on warm start.
No real indicators of what to check next. At this point maybe the chipset is to blame.
Feel free to ask more questions. I would really like the board to go to someone who wants to work on it and hopefully post back here so we can all find out why.
