Reply 40 of 45, by enaiel
mockingbird wrote on 2026-08-26, 14:25:
I have one too... Sorry for the small size of the pic (That's all I can do ATM):
The attachment ezra.jpg is no longer available
Thank you so much! It looks identical to my Ezra-T! Can you please post an image of the back of the CPU?
Here is my identical looking Ezra-T:
The attachment IMG_20201016_153024384.jpg is no longer available
H/W: VIA C3 DOS PC | PIII-S Tualatin Win98SE PC
S/W: VIAFSB FSB Util | VIAXFG SB Config Util
Reply 41 of 45, by mockingbird
enaiel wrote on 2026-08-26, 14:50:
My pleasure. Will you still be performing updates to VIAFSB by the way?
The attachment 2026-08-27-21-16-11-800.jpg is no longer available
The attachment 2026-08-27-21-23-04-384.jpg is no longer available
(Decommissioned:)
Reply 42 of 45, by enaiel
mockingbird wrote on 2026-08-28, 01:27:
Thanks, bit that is identical to my Ezra-T! I would expect the voltage to be 1.35V for Ezra and not 1.45V. Are you sure it's not an Ezra-T?
ViA C3 models are insane. All these are valid CPUs:
  • VIA C3 800MHZ 133x6 1.65V Samuel2 CPU
  • VIA C3 800MHZ 133x6 1.35V Ezra CPU
  • VIA C3 800MHZ 133x6 1.45V Ezra-T CPU
  • VIA C3 800MHZ 133x6 1.25V Nehemiah CPU
So confusing!
I would love to, but I am stuck as I have not been able to make any progress on making it work properly. If only I could see the source code for SoftFSB to see what trick I am missing!
Reply 43 of 45, by mockingbird
enaiel wrote on 2026-08-28, 02:29:
Ah, I apologize! It is in fact an Ezra-T. My Ezra is 900mhz (9 x 100) and lacks the capacitors at the top.
(Decommissioned:)
Reply 44 of 45, by enaiel
mockingbird wrote on 2026-08-28, 02:46:
No need to apologize - the VIA C3 CPU models are a royal mess. I think we need to create a database of all known VIA C3 models to save future generations from grief!
But in the meantime, the ViA C3 100x10 Ezra CPU remains a unicorn - never to be seen in the wild.
Reply 45 of 45, by mockingbird
enaiel wrote on 2026-08-28, 03:00:
See here:
https://www.hexus.net/tech/reviews/cpu/373-vi … -gold-cpu-1ghz/
The 1ghz Ezra (non-T) will have capacitors on at the top and bottom of the core but not at the sides. The one pictured is the 133mhz FSB variant, but if a 100mhz model existed, I don't see why it should be different.
It remains to be seen whether that stepping of the Ezra had write combining fixed, since it seems to be different than my 900mhz chip or the 933mhz chip pictured next to it at Hexus... We can clearly see that it's an Ezra by the 1.35v marking on the bottom.
I also want to add that in general, the FSB rating is not that relevant for Ezra (at least in Dos/Win9x), because although it's locked at post, you can override it with a utility at OS boot. So combined with something that changes your FSB, you can take a 7.5 x 133 chip and turn it into a 9 x 100 chip.
(Decommissioned:)
