Hehe, nice to know you got the board working again (like it always was?) 😁
Perhaps you have the magic touch? 🤣
When I worked in a repair shop some years back, I remember this happening a few times where owner/boss gave me some boards to look at, telling me they didn't work at all... and when I did look at them, miraculously, they all worked just fine. So he started joking every time when we get something in for repair, that I should just go touch it and it would magically be fixed afterwards.
Anyways, back to the topic at hand... I suppose one easy way to know if the board really has tacho monitoring and protection on CPU fan RPM failure is to just disconnect the CPU fan prior to powering on the board and see if it halts again. If not, then the fluke must have been somewhere else.
Repo Man11 wrote on 2024-11-16, 20:26:
There was a time when I smelled a burning electronics smell coming from the PC I had built for my mother. It was working fine, and I couldn't isolate the source of the smell. Maybe six to nine months after I had visited her and first noticed it, her PC stopped powering on. It turned out that the mediocre power supply had a loose fitting power cord, and the resistance eventually cooked the power cord's contact. Fortunately, I had come prepared with a spare power supply just in case. I later used a dead power supply to scavenge a socket, and used it for repair and the power supply worked fine.
Interesting.
I suppose a cheap & nasty power cord with loose contacts could indeed do that.
I have a few on hand like there... and always wondered if they would end up doing that. Probably should get rid of them.
BTW, I've also seen the 1/0 (On-Off) power switches on cheap PSUs end up bad and not make good contact... so that's another component that could do this.
