Reply 40 of 49, by bertrammatrix
feipoa wrote on 2025-03-27, 04:08:Here's an image of the 128 MB, 50 ns, EDO module I use on my M919. Shown is the front/back of the module. Only this module would allow for the exceptional performance and stability. Perhaps reach out to Memory Masters on eBay to see if they have any more.
Thank you kindly for that photo, I was actually going to ask you for your "secret sauce recipe" 😀
Indeed research points to the fact the the drive current available for memory on this chipset may be comparatively limited, which probably makes a difference when pushing it's capabilities. It would only make sense then that the board would be sensitive to the exact characteristics of the memory ic's used, with "newer", higher density designs likely being favored/ less drive required
My next possible step was going to be to acquire some sticks with thin Hyundai branded chips to try as they pop up here and there, however now knowing that you use Samsung ones I'll try to hunt those down.
Preliminary searches show none anywhere...that's usually a clue to that it may be good stuff 😁
