Reply 40 of 71, by shevalier
- Oldbie
bloodem wrote on 2025-02-10, 18:11:I don't usually like doing this to retro parts but, in my defence, I was having a lazy day when I did it 😅 ).
You can always drill the board
PS. The Vtt voltage is often made by a regulator, independent of the core voltage
For example, LT1086.
Therefore, it is easier to connect VttPwrGD with Vcc.
DynOE must be powered from Vtt.
Otherwise, the CPU will not set the BSEL (bus frequency selection) and ViD (voltage selection) status.
Otherwise, get ready for surprises - for example, an attempt to start on bus 133MHz with a voltage of 1.3 Volts.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
