Reply 40 of 54, by luRaichu
Did more research. The Promise SATA300 cards do not have Windows 98 drivers so not suitable for this build!
I found an 80 gig WD Caviar SE in my pile, it's SATA I. There is the Promise SATA150 series which will work properly with Windows 9x.
However I also saw one person using a Sil3114 card on an AMD K6-III+ system under Windows NT. Those cards are cheap but some people say they're not good for Socket 7 and below
Reply 41 of 54, by jakethompson1
luRaichu wrote on 2025-05-12, 21:02:
I am not sure if this is the exact issue you are suggesting but here goes.
I have one of those in my SE440BX-2 (Slot 1, Phoenix BIOS) and it works perfectly.
When I tried in my P5HX-A (Socket 7, Award BIOS 4.51PG) I encountered the following issue. Everything worked with loading the option ROM except when it was time to boot, somehow the Number of Hard Disks Attached byte in the BIOS Data Area (40:75) was zero. That blocked the BIOS from attempting to boot.
Using a little MBR on a floppy disk that would set that byte to 1, wait for any key so as to eject the disk, then attempt booting Int 19h again, it worked great as a proof-of-concept, demonstrating that nothing else was wrong.
I did find that having no IDE devices at all attached slowed down booting of the Award BIOS, even with everything set to "none." I think this is because for El Torito/Zip drive booting purposes, it probes for ATAPI devices anyway.
In a direct conversation with mkarcher about this, we wondered if it was because the BIOS Boot Specification was phasing in at this time, and if the SIL311x BIOS did not have the right fallback for a system BIOS that doesn't have it. (BBS is what enables that fancy boot order listing in the BIOS rather than just things like A,C and C,A). I am not sure whether those later Award BIOSes (that say A,C,SCSI vs. A,C) have this support or not. Anyway, maybe this is where the idea they aren't good on Socket 7 comes from.
Reply 42 of 54, by luRaichu
What about a VIA VT6421A card for my system? Seems popular with the Xbox modding people
Reply 43 of 54, by Repo Man11
My Sil3114 works well in certain systems, not at all in others. However, one of the systems it works well in has an Asus TXP4 which is also an AT motherboard with the TX chipset.
Here are the ATTO benchmarks with a K6-3+ @ 500 and an SSD with a Promise Ultra 100 and a Sil3114 flashed to the base (non RAID) BIOS.
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
Reply 44 of 54, by luRaichu
Good to know. Does your Asus board use the same version of the Award BIOS as mine?
Just want to make sure it’ll be compatible before I go and buy a Sil3114
Reply 45 of 54, by Repo Man11
luRaichu wrote on 2025-05-13, 15:39:
It's an Award 4.51, though I use the patched BIOS that Jan Steunebrink provided.
Reply 46 of 54, by luRaichu
Whoops, I forgot I’ll be using a PATA CD-ROM drive!
Does the onboard IDE controller on 430TX chipset play nice with the Sil3114? If not I need a VT6421A
Reply 47 of 54, by luRaichu
I’ve installed this motherboard in the desktop case, although a non-standard mounting standoff was shorting out the SIMM sockets from the underside and preventing a POST. I covered them with clear tape.
Unfortunately this case requires rails for mounting 5.25” drives. I only had one pair.
The attachment A2DF60E8-5982-4417-8455-0103670E3EA2.jpeg is no longer available
Then I found this thread where one member mentioned using thermoplastic to mold new rails. I bought 11oz of this stuff on Amazon for $6 and it turned out alright.
The attachment E7E4AC7E-08AA-4A29-8A13-E09602E2267C.jpeg is no longer available
To create the mold I put one rail on a smooth surface (glass) with the bracket facing up, then covered it with the molten plastic to create a mound. It can’t be too thick. The metal rail should be removed from the mold right before it hardens completely.
The same plastic is used for creating new rails in the mold. I applied mineral oil to prevent the hot plastic from sticking to the mold. But other oils should work as well. A paint scraper (or equivalent) helps to get the plastic flush with the mold.
The attachment 28159960-8AC0-4BF6-AE80-FBE1E488BF90.jpeg is no longer available
The resulting plastic rails fit fine and snug despite not having the bracket (too small to mold).
Since I’ll be using two 5.25” drives, I put a metal rail on one side and a plastic rail on the other. Reverse sides for other drive.
Reply 48 of 54, by luRaichu
But you can’t win them all. The ATI Rage II card that was tested and functional here doesn’t want to output video anymore (both VGA and NTSC composite). Windows will recognize it, load the driver, etc. but no video. I’ve only rarely seen it working now.
Whatever. They say it wasn’t good at playing Quake anyways.
Before cleanup:
The attachment 9B56AF62-17CB-4F3C-B372-E73D75A05EA3.jpeg is no longer available
The attachment 5CDAC9A8-9EA9-464E-A583-4725BBE6D9BA.jpeg is no longer available
The attachment 7896135B-7921-4F72-9750-1F832FBF9480.jpeg is no longer available
The attachment B460F8D2-3E09-4ECF-BD6F-7DF0F57F62A5.jpeg is no longer available
After:
The attachment 3F22EC93-9B0C-4983-BBCD-79B65FF9B142.jpeg is no longer available
Reply 49 of 54, by luRaichu
New VT6421A card installed but the BIOS does not list any devices attached to it. The included driver disc came with a big scratch which makes it unreadable 😀
Reply 50 of 54, by luRaichu
According to its datasheet the VIA VT6421A uses PCI 2.2 while the motherboard only supports PCI 2.1. So I don’t think it will work.
I guess I will have to buy a Sil3114 card and use an IDE to SATA adapter for the CD-ROM drive.
Reply 51 of 54, by luRaichu
I have the Sil3114 working in this machine. Did an install of Windows 98 just to make sure everything is OK. Wiped that and now I'm trying to figure out how I will dual boot NetBSD and Windows. NetBSD's installer didn't present the option to install its bootselector, probably because it is the only system installed at this moment.
Reply 52 of 54, by Chkcpu
Hi luRaichu,
In an earlier reply in this thread, I wrote about an 8500TTD patch J.2 BIOS that adds K6-2+/III+ support and fixes the 32GB IDE HDD limit.
I’ve just completed an updated 8500TTD patch J.3 BIOS, which was successfully tested by another Vogons member. This J.3 BIOS fixes an additional 64GB drive limit and has a fix for the UDMA Mode bug.
The attachment TTD_J3.zip is no longer available
Although you are using a Sil3114 card now, the fix for the UDMA Mode bug will still be beneficial for your PATA CDROM drive. Without this fix, any ATA/66 or faster drive on the onboard IDE channels will slow down to PIO mode 4 under Win98.
The patched BIOS also adds Write-Allocation support for K6-2CXT/K6-III/K6plus CPUs. The original TTD0616B BIOS only has WA support for the original K6, so the patched BIOS should give you an extra 10% performance on your K6-2/400.
Enjoy, Jan
CPU Identification utility
The Unofficial K6-2+ / K6-III+ page
Reply 53 of 54, by jakethompson1
luRaichu wrote on 2025-09-05, 02:31:
I just use dosboot.com due to the 504MB and 8.4GB limits among other things on my stuff. It just has to be a totally clean boot--no himem.sys (Shift+F5 for Win95 or F5 for MS-DOS) or it will fail mysteriously, such as by rebooting.
It also works best if the kernel is not gzipped, and in my case, I use a custom one that is TINY with minimal things (like PCI, pciide, piixide etc) added back in
Reply 54 of 54, by luRaichu
In my case the NetBSD bootselector works fine. I did get it to dual boot with Windows correctly.
The only problem is that the Ethernet NIC would work correctly in Windows, but not NetBSD. It was a Macronix MX98715AEC based card. It'd load the tlp driver alright.
I bought a 3Com 3C595-TX. We'll see if NetBSD likes it better.
Chkcpu wrote on 2025-09-06, 14:49:
This is really good to hear. I have been using the J.2 BIOS but I'll try the new version. I am running a K6-2 @ 500MHz, the stock BIOS reports it as 400MHz.
