ATI x850xt win 98 No vram
Reply 40 of 53, by rotzgurke
I am still Not able to Higher the Resolution above 1280x1024. 1600x1200 ist possible but does Not fit screensize and have to scroll. After reinstalling i am able to Set full hd ans Higher but trying that will prompt with No Signal. Settings Show me the evailability. Using Powerstrip let me Set full hd but after aome second Screen goes black and no Signal.
On another machine of Mine with x800 XL No Problems at alles even over füll HD with 85hz.
Reply 41 of 53, by Duffman
@rotzgurke
Swap the X800 XL and X850 XT between those machines and check if you see the same behavior on the other machine.
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 42 of 53, by rotzgurke
Duffman wrote on 2025-09-27, 00:22:
@rotzgurke
I wanted to avoid this but maybe better and i give it a try and reply than.
Reply 43 of 53, by rotzgurke
Okay same in another machine. Sad
Reply 44 of 53, by Duffman
rotzgurke wrote on 2025-09-29, 12:15:
Try recapping the card if you can.
CPU: Ryzen 9 5950X
Reply 46 of 53, by Duffman
The capacitors are old and might not be doing their job anymore, de-solder them and replace them with new ones.
CPU: Ryzen 9 5950X
Reply 47 of 53, by rotzgurke
Duffman wrote on 2025-09-29, 16:38:
Ah okay. Na, that would be no go for me. Idea great for the ones who can do that.
Reply 48 of 53, by DarthSun
rotzgurke wrote on 2025-09-29, 20:48:
Win98 likes to adjust the vertical refresh rate to around 100Hz for some cards.
Boot the system, select 640x480/8 bit -->reboot, then FHD/32bit/70Hz. Your monitor can handle 70Hz.
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 49 of 53, by rotzgurke
DarthSun wrote on 2025-09-29, 21:33:
I will try tomorrow
Reply 50 of 53, by Hans Tork
Once again I am not an expert but sometimes Win 98 se has messy graphics if you do not install the directx (whatever version you prefer) before the GPU. I faced a similar issue with some of the GPUs I tried on Win 98se systems and it seems you need to get directx installed followed by the driver. Reversing the order messes up things. Also it might be a good idea to do a fresh OS installation if you have switched hardware around.
Also judging from your initial post, you have a 775 board with 2GB RAM. Have you tried downsizing the RAM to 512 MB and checking if the GPU works as intended. Also if you intend to keep the RAM as it is you can also try RLOEW patches.
i7/Titan X/X-Fi- XP
P4/X800/Audigy 2 ZS- W98
P3/Voodoo 3 3000/AWE 64 - W95
Reply 51 of 53, by DarthSun
Hans Tork wrote on 2025-10-04, 23:54:
I also say that you need to install DirectX first.
And the Loew RAM driver is definitely above 512MB.
Reply 52 of 53, by rotzgurke
So i tried what you have Said. Nothing works finally. Even my gf 4 ti will only Go Up to 1600x1200 75hz.
A new Installation i do Not want to. May you have other ideas. I am confused
Reply 53 of 53, by DarthSun
Maybe just quotes, if that helps...
Excerpts:
Retro machine: https://logout.hu/tema/amd_k6-iii/hsz_69831-69831.html
Modern: https://logout.hu/tema/amd_k6-iii/hsz_121260-121260.html
Addon: https://logout.hu/tema/amd_k6-iii/hsz_74744-74744.html
